Originally posted by DJAM3
Depends on your motor mounts, but based on personal experience running rogue trans mounts and 75D motor mounts, no, they are not stiff enough.
Ended up being a not strong enough impact wrench. Bought a new one and they came right out.Originally posted by liam821 View Post
I would leave it in neutral so you're not loading the transmission, but keep the parking brake on. Although I can't imagine you could put enough torque using hand tools to hurt anything by leaving it in gear. It should break loose with a bit of effort, or you could try an impact driver (manual or battery-powered).
Next dumb question - Are Rogue transmission mounts stiff enough for a RTD shifter? I'd like to get rid of the NVH of 75D poly.
Is P0128 typically the resolved with a new thermostat? Not sure if hoping it goes away on its own is a wasted effort and I should just go ahead and change out the thermostat.
I would leave it in neutral so you're not loading the transmission, but keep the parking brake on. Although I can't imagine you could put enough torque using hand tools to hurt anything by leaving it in gear. It should break loose with a bit of effort, or you could try an impact driver (manual or battery-powered).Originally posted by DJAM3 View PostI'm in the process of dropping my rear subframe and I've run into difficulty breaking loose the driveshaft to diff torx bolts. Is there a trick to this or am I missing something? All the videos I've seen these come right off without issue with the tranny in neutral. Do I need to put it in gear?
