  • Slideways
    If they have that green O-ring, that means they'd need to be replaced, yeah?
    Yes, TIS states to replace the entire plug. I have taken out the o-ring to measure it and it shouldn't be too difficult to find a bag of replacement o-rings.
    The older style plugs, which I kept in case I want to revert back, did use a crush washer, but realOEM no longer lists a part number for the crush washer for the E46. You have to go to an older model, like the E31, where they still have it on the diagram funny enough.
  • sbay
    Any ideas on what to use to remove residue from cylinder walls?
  • IamFODI
    The ones on older cars had a crush washer, the ones you buy now have a green o-ring.
  • bmwfnatic
    Originally posted by BRiley View Post
    No crush washer then? Thank you so much!
  • BRiley
    This is the case for the differential since they have built in o-rings. Transmission plugs are reusable and don't have a sealing ring.
