I've done something to my passenger side parking brake and I can't figure what is causing the drag/lockup, so I'm obviously adjusting it incorrectly.... Anyone want to shed light on how to do it properly, I'm tired of screwing with it and feeling like an idiot. k thx
Here’s a video, I would blow into the area to clear the smoke and you can see how quickly it accumulates.Originally posted by jayjaya29 View Post
If it’s a large enough leak yes it can cause drivability issues.
If its a large enough leak yes it can cause drivability issues.Originally posted by Nate047 View PostBeen trying to un-fuck my other car little by little, I’m working on a series of vacuum leaks. I have a big leak at the base of the oil dipstick guide tube, probably that little O-ring. Do you guys believe a vacuum leak there could cause serious AFR deviations and drivability issues? Or am I likely going to continue to find more leaks downstream after I rectify this one?
How long ago was the VANOS rebuilt? typically a vanos rebuild should include valve adjustments, valve cover gasket, and possibly spark plugs.Originally posted by adr_M3 View PostI recently picked up a 2002 e46 with 98,300 miles that seemed to be well sorted with service records for rod bearings, VANOS, and basic regular maintenance (oil changes, brakes, etc). I took it to a reputable BMW shop here in LA who found the following faults/made the following recommendations:
- Leaking oil pan and constant pressure valve
- Brake and differential fluid flush
- Worn out engine mounts
- Valve adjustment
- Spark plug replacement
I didn't find service records for these and I wasn't expecting issues to pop up, so my question is whether these are known issues for a 98K vehicle and if there's a chance I'm getting taken for a ride by the shop.
