Located in California - SMOG related questions. Dumb question and I did some googling but couldn't find anything related to Martyn's MSS5x software.
If I used it for example enable shift lights I understand that modifying even something as small as that will fail smog.
I also understand that when using the MSS5x binary modification tool you take a backup.
If I just loaded that backup, is it to my understanding that that would allow me to pass smog?
Took them down to about 14mm and that seems to have done the trick. Bumper is on and aligned well. I think it's likely just the age of the rubber that gave me issues.Originally posted by Keith_MN View PostBumper mounting drama.
2004 M3. Front bumper was a little misaligned so I took it off to re-fit. Discovered the four mounting studs (part #17) that screw into the carbon crash bar were missing. Odd?
Ordered those. Installed them with the spacers on the middle two, no spacers on the outer two.
Bumper goes on, fits well, but will not click into any of the four studs with any reasonable amount of force. I feel like I'm going to start doing damage if I press harder.
I lightly sanded them to take off the very slight edges from production, gave them some light grease. Still no go.
Grease marks on the bumper sockets line up enough that some of them should go, but no.
Tried to press the stud into the bumper socket on it's own and it won't go.
Anyone else experience this? Is the culprit just the 20yo rubber not flexing at all?
Thinking about taking ~1mm off the studs so they slip in easier. As is, they are 15mm OD on the studs and 12.5mm id for the receiving socket.
https://www.realoem.com/bmw/de/showp...diagId=51_4734
For a track only car, smg to manual swap (ZF 5Spd)
Instead of properly wiring in the clutch switch, is there anything harmful being done by decoding the “Engine Start only in park or neutral gear”? From the EWS
This allows the engine to start without wiring the switch. I don't have a need for cruise control, but am I potentially missing on other requirements by side stepping the wiring?
Maybe you are having issues with the "tabs" many people need to remove.Originally posted by Keith_MN View PostBumper mounting drama.
Edit: I see this is not a replacement bumper, still check it out.
I ordered a genuine euro M3 front bumper through dealer part# 51117894989 for Kevlar support bar It came in and I got it painted then tried to install it only to see these 4 tabs on the backside interfering with the Kevlar bumper support. After some searching, those 4 tabs originally came in the aluminum carrier bumper to
ahh yeah it makes sense ! Mine is a ZCP 2005 with manual non-heated seats, no HK so it's suppose to have only 3 buttons from factory but I guess last owner changed it and it has the full 7 buttons now, even for the rear sunshade. I guess I just need the cover plate letting 3 holes for DSC, tire pressure, Sport.Originally posted by Avedis View Post
I don't know this for a fact, but it may point you in the right direction. I believe that these are made to be fairly modular. The base of it seems to act like a modular cage so you can add and remove switches/buttons. The face plate comes off the front which allows access to the switches.
My gut feeling is that you can do this:
buy a switch panel that has 3 buttons on it. LINK
remove/steal the face plate from that one
remove the face plate from your factory one. remove the switches you don't want (LINK showing the guts)
re-arrange buttons to your liking
install face plate from the second switch panel you purchased LINK
code??
Maybe someone else can chime in on this.Last edited by M3LSB.Gab; 03-07-2025, 05:10 AM.
