Can Anyone confirm the PN for the ground cable from the engine to the chassis? 12421737755?
Originally posted by Nate047 View PostOk diff mount questions.
Are the rear mount torx bolts (inside the cover) one time use only or can these be reused?
Is there supposed to be a washer between the mount and where it touches the subframe?
Anyone have an objection to using a different style of bolt of the same size and grade if I can't fit a torx socket on there? I have CMP subframe mounts
They actually don't show as TTY/"always replace" in the torque spec doc or TIS, as far as I could tell.Originally posted by liam821 View PostI've reused all my bolts without issue - however, I'm pretty sure they're all torque-to-yield and are considered single-use.
I see no issue with switching to a hex head if it's the same grade and length. Torx head is just for reduced chance of stripping. Not a bad idea tbh. No washer between the subframe and mount... https://www.realoem.com/bmw/enUS/sho...diagId=33_1076 . just for the mounting bolts.
I have cmp bushings, and initially had a tough time with the bolts as well. You need a lower profile ratchet and torque wrench. Check out my posts in this thread: https://nam3forum.com/forums/forum/m...ff-bolts/page4
Good to know it'll run. Will have to look into the latter part. I'm guessing yes. CA problems.Originally posted by liam821 View Post
Sure, you could, as long as you have the map sensor installed. I was able to pass smog in my state (Oregon) with a CSL tune. It depends on whether your state looks for modified code in the DME.
Sure, you could, as long as you have the map sensor installed. I was able to pass smog in my state (Oregon) with a CSL tune. It depends on whether your state looks for modified code in the DME.Originally posted by bavarian3 View PostHas anyone tried running a csl map sensor tuned car with a stock(standard m3) intake? Curious if it would run for smog purposes.
I've reused all my bolts without issue - however, I'm pretty sure they're all torque-to-yield and are considered single-use.Originally posted by Nate047 View PostOk diff mount questions.
