Driveshaft CV joint, just double checking #15 on this diagram is not needed, for non M cars that have the #20 cap cover thing. #21 is needed of course
Thank you.Originally posted by George Hill View Post
The picture of that pn# looks correct to me.
Saw this on ebay and look good too:
The picture of that pn# looks correct to me.Originally posted by 0-60motorsports View PostCan Anyone confirm the PN for the ground cable from the engine to the chassis? 12421737755?
Originally posted by Nate047 View PostOk diff mount questions.
Are the rear mount torx bolts (inside the cover) one time use only or can these be reused?
Is there supposed to be a washer between the mount and where it touches the subframe?
Anyone have an objection to using a different style of bolt of the same size and grade if I can't fit a torx socket on there? I have CMP subframe mounts
They actually don't show as TTY/"always replace" in the torque spec doc or TIS, as far as I could tell.Originally posted by liam821 View PostI've reused all my bolts without issue - however, I'm pretty sure they're all torque-to-yield and are considered single-use.
I see no issue with switching to a hex head if it's the same grade and length. Torx head is just for reduced chance of stripping. Not a bad idea tbh. No washer between the subframe and mount... https://www.realoem.com/bmw/enUS/sho...diagId=33_1076 . just for the mounting bolts.
I have cmp bushings, and initially had a tough time with the bolts as well. You need a lower profile ratchet and torque wrench. Check out my posts in this thread: https://nam3forum.com/forums/forum/m...ff-bolts/page4
