Changed my Xenon bulbs on my 2002 E46 M3 last night, and had the hood open for a while. When I took it for a spin, the gear # was flashing, after a while the Cog came on. Came back home and let it sit. This morning took it for a spin, same thing happened. Pulled codes via Inpa and got 52, 56, 53. Cleared everything and the gear # is still flashing, but no Cog.
Everything shifts fine, the parameters are all within spec - pump pressure is 50-70. But the gear light is flashing. The only thing I can remember is when I was changing the bulb, I noticed a wire that wasn't connected behind the headlights. I've cleaned the hood latches and the sensors. Drove it for about 15-20 min, no codes whatsoever. Swapped out a salmon relay, still flashing. Not sure what else to try. Thoughts?
