Just my .02 cents. I would follow BBR's recommendation. I rebuilt my motor with JE pistons, WPC treated rotating assembly. I wasn't sure either so I did the BMW recommended easy driving. I'm now dealing with oil consumption. I even used driven break in oil. I can't 100% confirm yet if it's the break-in procedure that caused the oil consumption. I'm hoping to confirm when I take the motor apart. It seems to smoke out of the exhaust (maybe when it burns oil the most) under heavy loads. The car runs fine without issues other than oil consumption and reduced MPG. But since I have to tear it apart and re-ring it. I will do BBR's recommendation.
thegenius, I think the 1500 idle would benefit you since you want the oil to flow to the head quickly as it breaks-in. Varying the loads is for the piston rings to set properly so you likely may not need to do it since your bottom end isn't touched.
