If I have an 11/2001 build date, does that mean my rod bolts are to be reused? Or is there a chance they changed the bolts when the recall was done?
11/2001 Build date rod bolts
Yeah you're fine. 04/02 here and had the reusable bolts. RealOEM says the cutoff was 02/03.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Here is a screenshot from the bulletin. If yours looks like A, the reusable M11, you can reuse.
I have not come across cars that are early years (pre 2003) with bearings done under recall and bolts replaced with new M10 (B). Probably partially because the lazy approach is usually just to reuse whatever was taken off.
Youtube DIYs and more
