Question for people with the Radium fuel rail and pressure gauge
    I'm considering the Radium Engineering fuel rail and pressure gauge but in some of the photos it looks almost like the gauge at the front of the rail would interfere with lifting the valve cover off. Does anyone have this set up? Can you confirm the valve cover clears the gauge?
    TIA
    I have it installed in my track car, there is no interference.
      Awesome, thanks!
        Also have it installed on my Street/Track car and no issues with interference of any sort. Super handy feature TBH, I am considering getting their Fuel FIlter setup with pre-FPR gauge as well one day....
          No with stock or stock style cover. But i have a hpf vented with horn, not possible to install, i buoght a few different fittings but, no luck, i live in the asshole of the world, so... Too much time ordering different pieces try to work, but... I let it without the gauge. Maybe one day.
            You guys see any discernible benefit to running the rail?
              At least the Sangria is good
                Not specifically - it's more the intangibles - like getting the Fuel Pressure Gauge makes it easier to try diagnose fuelling issues (ie if you are getting pressure to the rail) and the rail allows you to convert to AN connectors and hence more standard generic fuel hoses. The AN connectors and the Fuel Pressure Gauge is part of the main reasons I will convert to the Radium Fuel Filter setup at some point as well.
                I haven't personally gone to E85 but if you are going to E85 then getting the Radium rail and other bits allowing you to convert to generic fuel lines that are E85 compatible is potentially a neater (although also likely the most expensive) option.
                  TIA
                  Just in case anyone has this question in the future.
Name:	2023-08-13 17.57.51.jpg
                  2004 Dinan S3-R M3
                  2023 X3M Competition
                    thanks for this
