Mechanic said I need to replace the Center Support Bearing since the exhaust will be down? I will also replace the Guibo but was wondering if there is any other wear and tear item I should replace? Thanks.
Anything else I should replace while doing Center Support Bearing?
You'll need exhaust gaskets
The guibo will also need new bolts and nuts. There's really nothing else in there. You can do a fuel filter since the car up. Diff fluid if it's close to time. Maybe trans fluid since the heat shield will be out of the way.
Re-pack the CV joint06 ZCP SMG | HTE CSL MAP QuaranTune | SL CSL Airbox | Eventuri Scoop | DMG Strut Bar | RE El Diablo | CPI Euro200R | AP Headers | Porsche BBK | ST XTA | TMS 3-Pulleys/F-Sway/Mono FCAB | AKG Trans/diff/Subframe/RTAB | SPL RCA | SGT SCZA Trunk | ACL | Beisan | Redish | AFD E85 |
Budget CSL MAP Conversion
Transmission mounts, shifter bushings/linkage if 6MT.BMW / E46M Interior & Trim Restoration.
Order two of those drive shaft seals as they break really easily and they are cheap. ECS had to send me three before I got one that wasn't broken.2003 | 3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
Originally posted by antknee View PostMake sure you order a new seal between the cv joint on rear driveshaft that bolts to rear diff. My car is stuck on the lift right now bc i forgot to order that
Originally posted by oceansize View PostOrder two of those drive shaft seals as they break really easily and they are cheap. ECS had to send me three before I got one that wasn't broken.
Which part are you referring to here?
This one?
26111229078
This one. https://www.ecstuning.com/b-genuine-...xoCbIsQAvD_BwEOriginally posted by BMWahba View Post
This one?
26111229078
https://www.fcpeuro.com/products/bmw...03-26111229078
Got it , thanks a lot!Originally posted by antknee View Post
Same experience. Then when I finally got one that wasn't broken on arrival, it was so old and brittle that it broke taking the wax backing off of the sticky side smgdh. Ended up just JB-welding it back together and threw it in because it seemed impossible to guarantee that I could get one that was both fresh and intact.Originally posted by oceansize View PostOrder two of those drive shaft seals as they break really easily and they are cheap. ECS had to send me three before I got one that wasn't broken.
