SES engine light popped up the other day while daily driving, and when I ran the codes P0012 was a "confirmed" code, and P0010 was a "pending" code. Not sure what the difference is between confirmed and pending.
P0012: "A" Camshaft Position - Timing Over-Retarded
P0010: "A" Camshaft Position Actuator Circuit
Forum advice told me this was the Beisan Solenoid so I replaced that this afternoon along with the orings, and my P0010 code cleared, but P0012 remains. It seems unlikely that swapping the solenoid only cleared one code. Since both the codes appeared at the same time, I would expect one underlying issue to be the culprit, and as a result would've expected the new solenoid to either clear both codes, or neither of them. Do I need a new intake camshaft position sensor? Is there a test I can run in INPA to see if the sensor really is bad before I buy one?
