Help finding a parasitic power draw
    My battery dies pretty quickly, usually under 3 days.
    I was wondering what setups you guys use for detecting the amps with a multimeter. I was using jumper cables in the trunk with the leads to the mutlimeter, but discovered my fuse was blown in the mutli meter. Would the jumper cables make this ineffective as well?
    I ordered fuses, but of course was sent the wrong ones. I ordered the PowerProbe Draw Monitor as well. It appears to not have enough power if I disconnect the battery, the trunk lights do not stay on.
    Also not sure how to detect when the car is asleep. The Draw Monitor was showing 145mA and then 0mA. Is that when the car is asleep?
    When checking the fuses with DC Volts, should I use the 200m or 2000m setting?
    1) I was wondering what setups you guys use for detecting the amps with a multimeter. I was using jumper cables in the trunk with the leads to the mutlimeter, but discovered my fuse was blown in the mutli meter. Would the jumper cables make this ineffective as well?
    2) Also not sure how to detect when the car is asleep. The Draw Monitor was showing 145mA and then 0mA. Is that when the car is asleep?
    3) When checking the fuses with DC Volts, should I use the 200m or 2000m setting?
    1) what is the max amp of the meter in current mode? it's easier to connect the amp meter from batt - to the gnd cable, or from gnd cable chassic end to the car chassic. Set the meter dial to 5A or 10A, as the lowest setting might cause burned fuse.
    2) in sleep it should be around 10ma, not 0. your Draw monitor doesn't have good resolution and shown 0 when sleep.
    3) a burned fuse should show INF or mega ohms regardless what setting.
      sapote Do this while the battery is hooked up?
        to insert the meter leads into the batt current path, the batt has to be disconnected, then reconnect with the meter leads in series with the batt negative cable.
        so with the batt total amp now goes thru the meter, obviously the meter fuse will blow if you turn on the ignition, or some e-accessories with high current load.
          sapote So turn the lights off and the fan speed to 0? Will this effect trying to see if the FSR is the cause of the issue?
            when engine turned off the FSR is disabled normally (but damaged unit can drain current). Obviously you want to turn off all lights and everything for minimum sleep current drain.
              spec is 40mA (0.040A)
              Email to [email protected]
                you can also check all the fuses, under the glove compartment. Should be able to see anything that is drawing power, while the car is off.
                  332 Should I be checking for Voltage across the fuses? Should the value persist or appear for a second and disappear?
                    voltage, it should persist. You don't want to remove any of the fuses, just put the leads on the two metal "dots".
                      332 Let the car sit for an hour, with the passenger door open but with the catch thrown so the car doesn't think it is open.
                      Measured all the fuses and only had voltage on one fuse 43 (5 amp) which I think is the cluster.
                      With the probes one way it measured 12v the other way 0.03mV
                      Does that make any sense?
                        it's doesn't matter if the car knows the door is opened or closed, it will sleep after about 15 minutes with things unchanged.
                        The voltage across the fuse cannot be 12v or anything more than 0.5v as this is imposible. It should be fraction of mv, so you need to know the relationship between v and A before measuring the fuse voltage as they should be close to 0v for an untrained eye.
                          Pull that fuse, let us know tomorrow?
                            332 Any idea why I am measuring 12v across that fuse with two different multi-meters?
                              Can you measure from the fuse to a ground, does one side have 12v?
