Reinstalling the CD53 Radio
    After my Xtron headunit died, I have decided to try the CD53 again with a Blue Bus eventually.
    When connecting it back up, do you have to insert the bottom two connectors before you insert the large connector?
    It also appears I have misplaced the screws. Does anyone know the part numbers?
    The 10-pin is for CD changer, if you have one - must be inserted before you snap on the entire harness on. It is secured by a blue pin that is inserted from the side of the harness connector. The other bit I think is a fuse, no?
