i want to remove and refinish the center console and also the lower door panels- speaker surrounds. can you suggest a brand/color of canned spray paint that will yield an OEM like finish?
Best Paint to refinish center console
I can highly recommend Dulux DuraMax Flat Black. It dries in 10 mins so you can give it heaps of coats easily and you can give it a reasonably thick coat without running. If it runs simply sand back and redo after 30 mins. It is not flat IMHO but gives a nice satin appearance.
It gives a superior to OEM appearance IMHO. I did multiple coats with light sanding in between with excellent results. You can build up the aint this way to cover any imperfections in the plastic - and it doesn't flake off like the OEM rubbish.Last edited by poss; 10-11-2021, 11:40 PM.
A google search only seems to yield AU / NZ vendors selling this one, any chance you know where to get this in the US?Originally posted by poss View PostI can highly recommend Dulux DuraMax Flat Black. It dries in 10 mins so you can give it heaps of coats easily and you can give it a reasonably thick coat without running. If it runs simply sand back and redo after 30 mins. It is not flat IMHO but gives a nice satin appearance.
It gives a superior to OEM appearance IMHO. I did multiple coats with light sanding in between with excellent results. You can build up the aint this way to cover any imperfections in the plastic - and it doesn't flake off like the OEM rubbish.'04 LSB Coupe 6MT
I used Zinsser Perma for center console and it's my recomendation becoz it's very smooth out your center console.
