Doing my VANOS rattle fix, did my exhaust gear no problem but the stud in the middle of the intake gear sheared off. I'm thinking my only option is to just order a replacement, and I figured Dr. Vanos since it will have the rattle fix already done? Any thoughts?
VANOS intake gear stud sheared
Originally posted by r4dr View Postthe stud in the middle of the intake gear sheared off.
Did you measure any axial plays between the spline shaft and that LH threaded shaft? IF there is no plays then doing the rebuild is a waste of money/time and even ended up with negative effect (bearing too tight).
Interesting. Doing the rattle rebuild should not place any forces on that stud and so why it sheared off.
Did you measure any axial plays between the spline shaft and that LH threaded shaft? IF there is no plays then doing the rebuild is a waste of money/time and even ended up with negative effect (bearing too tight).'03.5 M3 SMG Coupe - Jet Black / Black
Thanks guys, appreciate the fast response. I texted Raj @ Beisan and unfortunately he didn't have any on hand. I ordered a Dr. Vanos one and I might have a line on a cheap stock one from eBay that I can send back in for a core charge refund. I *really* wish I had just bought the Dr. Vanos units in the first place – this has by far been the most frustrating and time-consuming part.'03.5 M3 SMG Coupe - Jet Black / Black
I may just buy the Dr. Vanos unit when the time comes, that is one of the procedures I feel a bit unsure about. Glad to hear you've got a part comming to get it all back in order.2004 Silbergrau Metallic 6MT
Originally posted by Cubieman View PostI may just buy the Dr. Vanos unit when the time comes, that is one of the procedures I feel a bit unsure about. Glad to hear you've got a part comming to get it all back in order.
Though if I'm being honest and didn't have so much free time to futz around with right now, I'd buy that $800 (after core refund) unit that a member offers for sale on here. And maybe spring for the coating.'03.5 M3 SMG Coupe - Jet Black / Black
