Originally posted by maupineda
Engine Overspeed
If you read carefully, he said he was doing pulls, he downshifted to 3rd at 60mph, which is fine, and climbed up and not paid attention to shift around the 8600 limiter and the engine blew, that said, it seems it was going to blow anyways, as said above, one visit to 8600 won't destroy an engine, it was either a constant over-reving that wore the engine down up to the point it couldn't take anymore or a mapping issue that caused severe detonation blowing it out. Regardless, sad about your engine OP
Originally posted by Apex_80 View Post
Yea I see what he was saying but to me if you're still under your decided rev limiter than it was not an overrev. Unless for some strange reason the limiter did not catch it and it went past 8600.
From what I could pull out the engine with a magnet, it looks like the alignment pins failed and that was it for the cap. It is in pieces, split just off center & I know CARR bolts wouldn't be the first thing to go when stretched properly. So I (tentatively) attribute this to cap failure @ +9k, on a set of rods that weren't Carillo's 😉
Originally posted by digger View Postthe dowel is for alignment only, the cap and rod are held together by preload and resulting friction. There are methods to improve transverse shear capability so you aren't relying on friction. What rods are these?
On a side note for those interested in validation, 440cc injectors running E85, held 12:1 AFR so definitely plenty of duty cycle; Whereas the stockers hit close to 90% DC on pump gas once you get up around 8500.
I've seen a stock motor hit 9k through a botched downshift on the track. It's still perfectly healthy some 3 years later. If you talked to track guys (and if they were willing to admit it) or had a way to log I'm sure you'd find a lot of these motors have seen some revs at a point or another. I'm more inclined to think it was an issue with the assembly or components personally.IG: @limited.slip
Alpine White E90 M3 6MT​
Alpine White 1 Series M
Originally posted by kaiv View PostI've seen a stock motor hit 9k through a botched downshift on the track. It's still perfectly healthy some 3 years later. If you talked to track guys (and if they were willing to admit it) or had a way to log I'm sure you'd find a lot of these motors have seen some revs at a point or another. I'm more inclined to think it was an issue with the assembly or components personally.
SliM3 show us more carnage pics? you can often tell if a bolt came loose / failed often
