Despite the extensive work I have done on my car and the 3xFSAE cars I have built in my time I am generally electrically illiterate. As part of my rebuild I went to a CSL battery and had replaced my Alternator... early on I found the rebuilt alternator I used was rubbish and I couldn't drive the car for long or afford to have it not on trickle charge... Since replacing the alternator with a brand new Valeo I have had no issues in that respect but I still have battery drain issues... if the battery is connected it will drain in ~1-2weeks... prior to my rebuild (admittedly with an OE M3 battery not CSL) I was able to leave my car for 7wks during and overseas trip without a charger and start it straight up when I got home... if I disconnect the battery (I have an isolation switch) I can leave it for over a week and reconnect it and it is still 100%... so obviously I have a battery drain issue.
I have a few candidates:
Can I measure something on the battery using my multimeter and then pull fuses from circuit one-by-one and be able to pickup which one is causing the drain? The way most of my things are wired in is hardwired and hidden so I don't want to remove panels until I confirm which one it is... but obviously if that is the best way to do it then I will...
So if anyone can provide some guidance on a nice logical way to try track it down that would be most appreciated. Understand that for most this may be a very dumb question so I am fully expecting and probably deserve some sarcastic responses haha. As long as one of them is some good helpful guidance then that would be great.
- CYHY Hidden Dash cam
- RaceCapture Track
- Avant-3
- BT OBD-II adaptor
- Radium Automotive Fuel Surge Tank Kit
- Battery Isolation switch
- CTEK Charging Panel
