gauges for those with CSL intake and tune
    I was shopping for gauges on ECS and I really like the P3 oem look, but they said it's not compatible with Euro software M3 ? I'm guessing it won't work with CSL software?
    Also really like the Awron ,but looks like they're no longer available, and probably won't work with CSL software either?
    any other clean gauge setup you guys can recommend?
    Following.
      What are you trying to monitor with the gauge? You won't need any additional gauges for CSL software.
      If you are running boost then that is a different story.
        It would be nice to monitor your AFR with the optional wideband o2 sensor, EGT, OIL temp, water temp if you track the car.
          Got it, that makes sense. So basically those gauges all would read straight from a US DME but not Euro/CSL?
          I guess I always figured those values fed to the aftermarket gauges had their own sensors/wiring to retrieve the info you wanted.
          I know people that have to smog their cars have issues with connectivity and everything comes up in German as far as reading codes etc. with a CSL tune.
            Hack Engineering sells a product called AK-Motion DataDisplay. According to Ben, its works with CSL software and shows intake temps. Doesn't show manifold pressure but suggested its being worked on since boost pressure will soon be available. This was as-of July.
              The e46m has non buffered oil and coolant temp gauges already.
                Oil and water temp is visible in cluster, so should be no need for that.
                EGT, IAT etc is only accessible via K-line (from obd) and found out while doing research for a DIY display the read command for this is the same on every MSS54 (mss52 and even ms42,43 etc share some of the commands, but not all), regardless of Country version. MAP value and Oil level for example is only possible on CSL Software.
                …under construction.
