Early models bumper support adjustment
    Can these posts adjusted in and out?
    not up an down
    From what I recall they can't be adjusted in and out.
    They are adjustable up and down, but if they've anything but brand new/out of box the threads are usually seized.
      I suppose you could use a spacer of some sort to adjust them out. Of course you'll have to drill out the rivets if they are still holding the supports on.
      Sent from my Pixel 3 using Tapatalk
        I actually want to move it in
          Maybe have them cut shorter then weld back. Maybe not worth it at that point tho
            Sounds like you're trying to install a CSL style bumper... I know the status gruppe ones had that issue. I have the same bumper and I have real Euro / CSL bumper shocks and they still don't fit that bumper.... they actually need to go in a little bit. they can either be cut shorter and rewelded or you can drill out the shock a little bit to relieve pressure push the bumper shock in.
              I actually moved from a Kevlar to aluminum support due to my intercooler, so I got a pair of shocks and a plastic inner insert from a 3 series bumper and molded it to my factory bumper cover then installed the aluminum support
              posted pics on my Instagram account
              frankenstein_m3
