Stock thumpets out of the stock airbox - same as the CSL turmpets.
Painted
My clamp design
Stock boot on the left
Test fit
Also designed a PCV catch can to route brake booster and valve cover vent, it connects on the bottom to the stock oil return
Literally, the only thing that cost any money was the ITG filters ($22/each)
The PCV can was my first beta print, I was going to reprint one in black or paint it black - I just had a bunch of white filament.
All hooked up.
For tuning, I'm running MSS54HP non-h-bridge DME using a stock CSL tune with a CSL MAP & IAT sensors. Runs great, sounds amazing. I've designed a plate to go under them to help direct airflow into the trumpets, but I haven't put it on since I'm not sure if I want to keep this setup or not.
But it's the PCV system, running an open PCV sucks - just sticks. The stock system dumps back into the airbox so you don't smell anything, but running open velocity stacks there really isn't a good place pipe that back into the intake. I've thought about running hose into the exhaust using a venturi valve, or perhaps routing it through an oil separator/oil catch can and then into the IACV...but I'm not sure I want to route it directly into the IAVC - sounds like a great way to gump up the IACV. What do other people do? Thoughts?
Probably my best option is to use a CSL style airbox...so that's why BMW made that eh.
