Eventuri Intake problem
    Hopefully someone smarter than me can help. I was taking apart my Eventuri Intake to clean the Filter and when I pulled it apart, a rubber band seal fell off and for the life of me I didn't see where it came from. I thought maybe it went around the Carbon Housing, where it butts up against the shield, but the photos on the Internet don't show it there and when I put it around the Filter where it slides into the Carbon housing, it gets all bunched up. I should have probably left it together, but I thought I needed to take it apart to clean it properly, Maybe it's not that important, but the Darn thing is there for a reason I thought maybe an expert on here can educate me. Thank you for any help
    number 6 maybe?? goes over intake manifold and then elbow goes over it.
      Was the same! I even don't understand from where was that rubber, so i just throwed it away
        Gosh! I'm sorry you had the same problem, but I'm happy I'm not the only one in the world that couldn't figure it out. I'm usually pretty good at figuring things out, but this one has me puzzled. All I wanted to do was clean my Air Filter and when I'm pulling it out of that Carbon Fiber housing, Poof! I've got this Big Rubber band sitting in my Lap and I'm sitting there thinking to myself Where the Hell did that come from. There seemed like only two logical places, outside the whole Carbon housing, but the Photos don't show that or around the Lip of the Filter next to the Gasket with the Screw Holes in it where it inserts into the Housing, but with that Band on the Filter, the gap is so tight it keeps getting all crunched up trying to slide it back in the that Housing with it on and also pushes out that Gasket. . I'm like you and feel like tossing it, because it doesn't even look like it's needed, but it still Bugs the Crap out of me that I wasn't able to see where it came from when I pulled it apart. I sent an Emal to Eventuri with a photo and even they couldn't tell me where it goes. There has to be someone in the World with an E46 M3 Eventuri Intake that knows where this Band goes.
          Originally posted by Rajvosa View Post
          https://www.realoem.com/bmw/enUS/sho...diagId=11_3012
          ^ This. It looks like the seal for the intake elbow and not related to the CF intake.
            I checked my photos right after installation, and I realized that this rubber was there from the very beginning, it's a pity I could not find a photo when I got it out of the box, I asked the master, he says that there was a rubber and he thought that it was right)
              It's way too big for the Elbow and it fell out when pulling the Filter out of that Carbon Housing. The Gasket looks like enough to give a good seal and prevent any airflow other then through the Filter, but that Rubber Band came from somewhere. I guess Evolve put it in there to mess with me and it really doesn't serve any purpose.
                fair enough.
                Hard to judge size
                of the gasket but just want to confirm it’s meant to be at the end of the elbow that meets the intake manifold itself, not the lower part of it.
                good luck
                  Why not call/email Eventuri?
                  I would not throw out, if they took the time to fit it with the product it probably was deemed necessary.
                    Thread bump, just bought a replacement filter, and now I have the same dilemma. Anyone know where this rubber gasket goes?
                    My replacement filter came with 2 of those foam gaskets, old one was just using one of foam gaskets. I installed both foam gaskets so it's sandwiched between 2 foam gaskets.
                      I was looking through some pictures of when I did my eventuri install a couple years ago. I recall something about this too. For some reason, I took a picture at the time of something I had to order from fcpeuro for my install- part # 11617830104​ (#9) on the realoem diagram posted earlier. I took a picture of that part for some reason - maybe it was for this! Hope it helps - not sure.
                        Thanks for the reply, nope its not that part. This rubber ring is more like a stretchy rubber band and is much bigger. It definitely came out when when i took apart the Eventuri air filter.
                          It goes around the housing, and wraps around the carbon edge and sandwiches by the foam gasket and the velocity stack. I will take a photo tonight and post here.
                            Yea thanks, Eventuri got back to me and mentioned the same thing.
                            From Eventuri:
                            That is just for aesthetics to go around the outside of the filter housing and cover the interface between the carbon and the edge of the filter.
                              Did you have difficulty fully seating the MAF housing into the factory elbow with this new gasket? I just installed mine a few days ago and replaced that gasket and was able to get it but was definitely a far tighter fit. Took some rocking back and forth to get it to seat.
