Hi everyone,
So I will be getting my subframe reinforced in the spring (Reddish plates) and wanted some advise on what subframe bushings to go with. I've pretty much decided to stay with OE bushings for the diff (I dont want to deal with the additional NVH) and have narrowed it down to the two options for the subframe:
1. CMP solid bushings (I've read due to the added stress the solid bushings cause, you have to reinforce the top side as well. Is this necessary?)
2. AKG 95A Bushings.
What would you guys recommend or are there any other options I should look at? The car will primarily be used as a street car.
Thanks for the help guys!
