Subframe Bushing Help
    planning out my RCAP project, and it seems like solid subframe mounts are a good idea even if I'm focused on maintaining minimal NVH for highway cruising. Is there a consensus on the "raising" bushes from CMP to correct some suspension geometry on lowered cars, vs the standard solid aluminum mounts from BW?
      I ordered and received the reddish reinforcement kit. Does this kit come with the topside mounts or would I need to order those from CMP?
      OP I opted for AKG95. I don’t track the car at all and it’s pretty much a garage queen with some spirited driving. I’m going oem with diff cover and all other bushings.
        Redish is bottom side only.
          Thanks. I’ll order the 1.5 kit from CMP which covers the top side.
