Originally posted by Obioban
View Post
Flat Ride, Bounce Frequencies and Tires: A Question
Best link to how to calculate/setup flat ride? I'm interested in looking into this for both my e36 and e46.
I don't buy that our cars have "Snap" Oversteer. If you set up your suspension using the Flat Ride theory and your Front Roll Coupling (FRC) is within the normal range (72ish?), the car should behave in a very predictable and controllable way. Even if your tires are slightly over inflated and your back end starts to slide, it is still very predictable.
I have been in an NSX, a car known for snap oversteer, during one of these scenarios and it felt very different from my M3 at its limits. However, I am no expert and this is just what my past experiences have told me. Maybe this guy has seen an event where the tires were so stiff and the FRC was so high that the car exhibited snap oversteer qualities?Last edited by Johnvu; 01-20-2021, 10:04 AM.
Cool, I'll see if I can find it and figure it out.Originally posted by r4dr View Post
It looks intimidating but it’s pretty intuitive after a while.
There’s a thread somewhere on here outlining the concept + thinking behind flat ride and how to use the spreadsheet.
This document from OptimumG is a pretty good summary of the theory behind ride frequency selection and how it relates to spring rate.Originally posted by Nate047 View Post
Thanks, I'll take a look when I have some time to read and really pay attention lol.Originally posted by timmo View Post
In stock form our cars are neutral with FRC around 75% but since it comes with a staggered wheel/tire set up to understeer more how much of an effect does a square wheel/tire set up play in that percentage?
Wouldn't just changing to a square set up induce more oversteer?
Then when figuring out a good FRC % shouldn't we be trying to calculate that in to the equation?
This might be the dumbest question ever but i'm over here trying to figure it out.
Larger front tires (more front grip) would tend to reduce understeer, yes. But front roll couple (FRC) isn't a simple oversteer/understeer/neutral indicator. It's a numerical representation of how much of the car's total roll stiffness comes from the front suspension. The value has nothing to do with tire size, compound, etc.Originally posted by lvm3sm46 View PostIn stock form our cars are neutral with FRC around 75% but since it comes with a staggered wheel/tire set up to understeer more how much of an effect does a square wheel/tire set up play in that percentage?
Every car is going to be different. IMO, the FCM spreadsheet is most useful for seeing how changes to a particular suspension setup will affect ride and handling.2003 Imola Red M3 w/ SMG
