So after issues with timing my engine after my Vanos work I've come to the conclusion my problem is likely from the slack in the timing chain.
Here is a video of the slack, just for visual reference:
To properly time the engine I must set the crank JUST before TDC, the crank locking pin is unable to be inserted.
If I set my cams up while the crank locking pin is installed the timing bridge does not sit flat, I've tired numerous times and I always end up with a small gap on intake side for both cams, the exhaust cam having the larger gap of about 1mm.
I have heard on the this forum that it might be OK to "cheat" the timing as I am doing, but after talking with a local BMW shop and the main dealer they didn't think that is the greatest idea.
The indie shop recommended replacing the tensioner as maybe the spring isn't 100%.
If I'm over-complicating things, sorry, but I just wanted to get a few more opinions as far "cheating" the timing goes.
