e46 Stereo Wiring Guide
    Laid out as follows
    (Pin location on connector) (wire color code) (function)
    Radio Main Plug X18126 (quadloc)
    Pin 1 blue/black - RH Rear loudspeaker +
    Pin 5 brown/orange - RH rear loudspeaker -
    Pin 2 black/red - RH front loudspeaker +
    Pin 6 brown/orange - RH front loudspeaker -
    Pin 3 yellow/red - LH front loudspeaker +
    Pin 7 brown/orange - LH front loudspeaker -
    Pin 4 yellow/black - LH Rear loudspeaker +
    Pin 8 brown/orange - LH rear loudspeaker -
    Pin 9 Wht/red/yellow - I-bus
    Pin 10 Black - Telephone mute
    Pin 11 white - Tel on
    Pin 12 brown - Radio ground Ground point (gnd)
    Pin 13 White - Antenna supply (remote)
    Pin 14 Grey/Red - Nighttime illumination signal Light module
    Pin 15 Vi/white - Terminal 30 Fuse F56 (+12v battery)
    Pin 16 red/green - Voltage supply terminal R Unloader relay, terminal R (+12v ignition)
    Radio Plug X13321 (white)
    Pin 1 - Not used (line out, left)
    Pin 3 - Not used (line out, GND)
    Pin 7 - Not used (line out, right)
    Pin 2 white/brown - Ground CD changer
    Pin 8 white/blue - Positive left CD changer
    Pin 9 white/red - Positive right CD changer
    Pin 4 - Not used VCR Right, in)
    Pin 5 - Not used VCR Left, in)
    Pin 6 - Not used VCR GND, in)
    Pin 10 - TV/Video module Right
    Pin 11 Yellow - TV/Video module Left
    Pin 12 Blue/yellow - TV/Video module Gnd
    Radio Plug X13598 (black)
    Pin 1 blue/brown - + Cassette/CD right On-board monitor
    Pin 2 blue/brown - - Cassette/CD right On-board monitor
    Pin 7 Yellow/black - + Cassette/CD left On-board monitor
    Pin 8 yellow/brown - - Cassette/CD left On-board monitor
    Pin 3 - AUX In left
    Pin 4 - AUX In Right
    Pin 10 - AUX In GND
    Pin 5 Blue/yellow - Audio AF+ Navigation module
    Pin 11 yellow - Audio AF- Navigation module
    Pin 6 black - Telephone In +
    Pin 12 yellow - Telephone In -
    Pin 9 - Nav Bus
    Amp Connector -- The Connector is laid out as follows
    13_21 __ 34_42
    12_20 __ 33_41
    11_19 __ 32_40
    10_18 __ 31_39
    09_17 __ 30_38
    08_16 __ 29_37
    07_15 __ 28_36
    06_14 __ 27_35
    _ 05 _____ 26
    _ 04 _____ 25
    _ 03 _____ 24
    _ 02 _____ 23
    _ 01 _____ 22
    Speakers
    34 - yellow/brown - front left tweeter -
    33 - yellow/red - front left tweeter +
    39 - blue/white - front left mid-range -
    40 - white - front left mid-range +
    3 - blue/brown - front left woofer -
    4 - blue/white - front left woofer +
    12 - blue/brown - front right tweeter -
    11 - blue/black - front right tweeter +
    41 - blue/green - front right mid-range -
    42 - green - front right mid-range +
    22 - blue/brown - front right woofer -
    23 - blue/red - front right woofer +
    32 - yellow/brown - rear left tweeter -
    31 - yellow/black - rear left tweeter +
    1 - brown - rear left speaker -
    2 - yellow - rear left speaker +
    21 - blue/yellow - rear right tweeter -
    13 - yellow - rear right tweeter +
    24 - brown - Rear right speaker -
    25 - blue - rear right speaker +
    HU speaker out
    9 - brown/orange - rear right - AF radio from HU
    8 - blue/black - rear right + AF radio from HU
    29 - brown/orange - rear left - AF radio from HU
    37 - yellow/black - rear left + AF radio from HU
    17 - brown/orange - front right - AF radio from HU
    16 - black/red - front right + AF radio from HU
    30 - brown/orange - front left - AF radio from HU
    38 - yellow/red - front left + AF radio from HU
    HK Amp
    5 - red/green - terminal 30 from fuse F41
    10 - white - antenna switching signal from HU
    15 - yellow/black - from spatial sound button on dash
    20 - black/white - speedometer output from instument cluseter control module
    26 - brown - ground to chassis
    HK amp to Sub
    6 - green - + positive activation for subwoofer from HU
    14 - blue/green - negative activation for subwoofer to sub amp pin 6
    7 - white - subwoofer switched to sub amp pin 2
    19 - black/green - speedometer signal to sub pin 7
    Subwoofer Amp
    6_7_8_9_10
    1_2_3_4_5
    1 - green - + positive activation from amp pin 6
    6 - blue/green - - negative activation from apm pin 14
    2 - white - subwoofer switched from amp pin 7
    7 - black/green - Speedometer output from amp pin 19
    4 - brown - ground to chassis
    5 - red/green - Terminal 30; power from fuse F41
    Color Codes:
    braun BR = brown
    blau BL = blue
    rot RT = red
    gelb GE = yellow
    grau GR = gray
    schwarz SW = black
    weiss WS = white
    grun GN = green
    orange OR = orange
    rosa RS = pink
    violett VI = violet
    Cheers for that.
    May come in hand and is a time saver.
      Definitely useful. Thanks mate!
        Thanks! Very helpful.
