e46 Stereo Wiring Guide
    Laid out as follows
    (Pin location on connector) (wire color code) (function)
    Radio Main Plug X18126 (quadloc)
    Pin 1 blue/black - RH Rear loudspeaker +
    Pin 5 brown/orange - RH rear loudspeaker -
    Pin 2 black/red - RH front loudspeaker +
    Pin 6 brown/orange - RH front loudspeaker -
    Pin 3 yellow/red - LH front loudspeaker +
    Pin 7 brown/orange - LH front loudspeaker -
    Pin 4 yellow/black - LH Rear loudspeaker +
    Pin 8 brown/orange - LH rear loudspeaker -
    Pin 9 Wht/red/yellow - I-bus
    Pin 10 Black - Telephone mute
    Pin 11 white - Tel on
    Pin 12 brown - Radio ground Ground point (gnd)
    Pin 13 White - Antenna supply (remote)
    Pin 14 Grey/Red - Nighttime illumination signal Light module
    Pin 15 Vi/white - Terminal 30 Fuse F56 (+12v battery)
    Pin 16 red/green - Voltage supply terminal R Unloader relay, terminal R (+12v ignition)
    Radio Plug X13321 (white)
    Pin 1 - Not used (line out, left)
    Pin 3 - Not used (line out, GND)
    Pin 7 - Not used (line out, right)
    Pin 2 white/brown - Ground CD changer
    Pin 8 white/blue - Positive left CD changer
    Pin 9 white/red - Positive right CD changer
    Pin 4 - Not used VCR Right, in)
    Pin 5 - Not used VCR Left, in)
    Pin 6 - Not used VCR GND, in)
    Pin 10 - TV/Video module Right
    Pin 11 Yellow - TV/Video module Left
    Pin 12 Blue/yellow - TV/Video module Gnd
    Radio Plug X13598 (black)
    Pin 1 blue/brown - + Cassette/CD right On-board monitor
    Pin 2 blue/brown - - Cassette/CD right On-board monitor
    Pin 7 Yellow/black - + Cassette/CD left On-board monitor
    Pin 8 yellow/brown - - Cassette/CD left On-board monitor
    Pin 3 - AUX In left
    Pin 4 - AUX In Right
    Pin 10 - AUX In GND
    Pin 5 Blue/yellow - Audio AF+ Navigation module
    Pin 11 yellow - Audio AF- Navigation module
    Pin 6 black - Telephone In +
    Pin 12 yellow - Telephone In -
    Pin 9 - Nav Bus
    Amp Connector -- The Connector is laid out as follows
    13_21 __ 34_42
    12_20 __ 33_41
    11_19 __ 32_40
    10_18 __ 31_39
    09_17 __ 30_38
    08_16 __ 29_37
    07_15 __ 28_36
    06_14 __ 27_35
    _ 05 _____ 26
    _ 04 _____ 25
    _ 03 _____ 24
    _ 02 _____ 23
    _ 01 _____ 22
    Speakers
    34 - yellow/brown - front left tweeter -
    33 - yellow/red - front left tweeter +
    39 - blue/white - front left mid-range -
    40 - white - front left mid-range +
    3 - blue/brown - front left woofer -
    4 - blue/white - front left woofer +
    12 - blue/brown - front right tweeter -
    11 - blue/black - front right tweeter +
    41 - blue/green - front right mid-range -
    42 - green - front right mid-range +
    22 - blue/brown - front right woofer -
    23 - blue/red - front right woofer +
    32 - yellow/brown - rear left tweeter -
    31 - yellow/black - rear left tweeter +
    1 - brown - rear left speaker -
    2 - yellow - rear left speaker +
    21 - blue/yellow - rear right tweeter -
    13 - yellow - rear right tweeter +
    24 - brown - Rear right speaker -
    25 - blue - rear right speaker +
    HU speaker out
    9 - brown/orange - rear right - AF radio from HU
    8 - blue/black - rear right + AF radio from HU
    29 - brown/orange - rear left - AF radio from HU
    37 - yellow/black - rear left + AF radio from HU
    17 - brown/orange - front right - AF radio from HU
    16 - black/red - front right + AF radio from HU
    30 - brown/orange - front left - AF radio from HU
    38 - yellow/red - front left + AF radio from HU
    HK Amp
    5 - red/green - terminal 30 from fuse F41
    10 - white - antenna switching signal from HU
    15 - yellow/black - from spatial sound button on dash
    20 - black/white - speedometer output from instument cluseter control module
    26 - brown - ground to chassis
    HK amp to Sub
    6 - green - + positive activation for subwoofer from HU
    14 - blue/green - negative activation for subwoofer to sub amp pin 6
    7 - white - subwoofer switched to sub amp pin 2
    19 - black/green - speedometer signal to sub pin 7
    Subwoofer Amp
    6_7_8_9_10
    1_2_3_4_5
    1 - green - + positive activation from amp pin 6
    6 - blue/green - - negative activation from apm pin 14
    2 - white - subwoofer switched from amp pin 7
    7 - black/green - Speedometer output from amp pin 19
    4 - brown - ground to chassis
    5 - red/green - Terminal 30; power from fuse F41
    Color Codes:
    braun BR = brown
    blau BL = blue
    rot RT = red
    gelb GE = yellow
    grau GR = gray
    schwarz SW = black
    weiss WS = white
    grun GN = green
    orange OR = orange
    rosa RS = pink
    violett VI = violet
    Cheers for that.
    May come in hand and is a time saver.
      Definitely useful. Thanks mate!
        Thanks! Very helpful.
          Is the wiring chart the same for HK navigation system for convertibles?
          04 M3 Vert by way of sunny SoCal to S. NJ / Philly.
