Clanking noise
    Clanking noise
    I’ve noticed a light clanking noise. It’s sorta like a metal or tin noise like when the chassis or suspension is under load. Turning into my driveway (uphill) or going over bumps as slow speed. Sometimes I hear it when I move the car up a feet and I only hear it at low speeds. It’ll only clank one time, it’s not a constant noise. It sound like it’s coming from the rear of the vehicle.
    I have Kw v2 coil overs and I recently changed the guibo, center bearing, and power flex rtabs. My RSM were never changed (or at least I don’t remember).
    Thanks in advance.
    I have the same deal, it happens every time I back out of the garge. Its just after I turn the wheel slightly to come out of the garge at a slight angle, not an alarming noise, but I notice it every time.
    I guess I figured it was something to do with the rack as its when I turn the wheel.
      I know you said it sounds like it's coming from the rear, but check the FCABs. Mine made a similar noise when they were shot...low speeds over bumps and going over slight pitch changes at angle (i.e. leaving a driveway).
        Pretty much every E46 M3 I've been in and owned has this noise that you're describing. Including my current one which I've replaced every rear end and driveline bushing. I believe it comes from the diff. Wouldn't sweat it.
        Current:
          I had one for the fcabs replaced back in 2016. I told the shop I wanted both replaced and they were being stubborn about it. I was thinking of having both replaced .
          thanks.
