Hey all, haven't posted much since the M3forum days. I had a build thread on there about this car, but sadly the thread was lost when the old forum went down. I've got a 2000 328i sedan with an S54 swap that I completed about 3-4 years ago. I did all the mechanical and wiring work and I sent the cluster and DME to Kassel to program and delete EWS. It's been running fine for years. In the last month or so I've started to have an intermittent starting issue. It started with the key not doing anything. After a couple more attempts to turn the key, it would finally start in the times where it wouldn't start there would be no noise from the starter, and the only noise would be the fuel pump when the key was turned. This happened a few times but I could always get the car started with a few cycles of the key. Then I ran to the store a few weeks ago and the car would not start at all when I came back. I tried the key 15+ times and nothing happened. I called my brother and he came over with a few tools. We tried tapping the starter and still couldn't get it to start. We ended up bump starting it and I drove it home.
The next few days it started up first try, and then I'd get a day where it wouldn't start at all and I'd need to bump start it. I heard the solenoid on the starter can go out, so I checked the starter. You can jump the starter and it starts the car fine. I replaced the clutch switch to no avail. I found a forum post where someone was having my exact intermittent issues and what fixed it for him was replacing the bolt down 50 amp breaker fuses for the starter which are located behind the fuse block in the glove box. I replaced those two days ago and my car was starting up every time, until this morning. Now it won't start at all today. I used my Schwaben scan tool on it and looked at live data for the EWS. Nothing was blocking the starter from starting, but two things that caught my eye were "key identification: ok", "key password: not ok" and "key random code: not ok".
I've got two keys for the car. One that came with the car when I bought it in 2014, and one that I bought from my local dealer within the first year of my ownership. Both will lock and unlock the car fine, but neither one will start the car right now. The original key that came with the car comes up on the scan tool as key #1, and the replacement I bought comes up as #5. both keys come up with "key identification: ok", "key password: not ok" and "key random code: not ok" on the scan tool when I'm trying to start the car with them.
Sorry for the rambling mess. I'm kind of at my wits end at the moment and I'm hoping someone else has some helpful things to check.
Thanks,
Jared
Thanks,
Jared
