What projects would you trackle in quarantine?
    Looks like some of us are already under lockdown while others are not to far away from it. What projects are you guys looking to tackle?
    I have the F80 M3 lithium-ion battery that I want to figure out, install BBK if it ever shows up from California, corner balance and finish a few interior details.
    Here's my plans. I'm probably not going to get them all done, but it's what I'm shooting for:
    Hardwire in my Valentine One and front and rear dash cams
    Oil change/valve cover gasket
    Swap back to Summer wheels
    Figure out why my rear defrost triggers my battery light
    Powder coat some control arms and a valve cover for a friend
      Here are my plans
      - Porsche BBK conversion
      - Rear Window Stripping
      - Much needed car detailing inside and out
      - Sound system refresh / tune
        Just did some maintenance since I’m stuck in the house...
        -oil change
        -greased up TMS FCABs
        -adjusted newly instead coilovers(camber and height)
        -new plastic bellypan
        -new AC belt
        Ill probably do a Guibo and trans fluid over the next week.
        Instagram: @_Frank_Stone_
          We're already pretty well locked into, so I'm a decent way into my quarantine car project list. Items in red are done, items in black still need to be done...
          General:
          Build corner balance scale levels
          fix detached garage dehumidifier
          M3:
          -install new sway bars
          -document rear camber
          -swap front camber plate inserts
          -swap front spring rates
          -set front ride height based on bump/droop travel
          -set rear ride height based on .5” front/rear stagger
          -set rear bump/droop ratio (note: total travel = 143.5mm
          -reset rear camber
          -corner balance
          -set sway bar preload
          -oil change
          -brake fluid change (unless it seems like track season isn't happening)
          -Light weight headlights (LED)
          M5:
          diff fluid
          trans fluid
          cabin air filter
          engine air filter
          oil change
          brake fluid
          timing chain tensioner
          bluebus
          seat angle repair
          low priority: headlights lens
          332iT:
          oil change
          Fuel pump
          Fuel filter
          Soften front sway
          projector upgrade
          M3 mirrors
          Wire up TPMS button
          rear brakes
          brake fluid
          summer wheels/tires
          i3:
          Summer wheels/tires
            Planning on doing my valve cover gasket.
              [INDENT][INDENT][INDENT]We're already pretty well locked into, so I'm a decent way into my quarantine car project list. Items in red are done, items in black still need to be done...
              General:
              M3:
              -reset rear camber
              -corner balance
              -oil change
              Are you still runnning Ohlins?
              Also - which LED headlights are you picking up?
              Current:
                Redid my seats, and my head liner
                • dummptyhummpty
                  dummptyhummpty commented
                  Editing a comment
                  Any details on this?
                So far I've done:
                Rod bearings (VAC)
                CDV delete
                Finally fixed the broken studs on the corners of my valve cover
                Ran new NiCopp brake lines from front to both rears as well as the clutch hard line
                Replaced power steering return hose
                Still to do:
                Clean and paint front/rear subframes while they are out
                Paint my new reman brake calipers
                Replace steering coupler
                Install ECS SS brake lines
                Replace power steering pressure hose
                I've had no problem keeping myself busy during this quarantine! Unfortunately it looks like Watkins Glen will be closed for the April track day I was supposed to do though :/
                  Have yet to be subjected to a stay at home order here in VA, but I've pretty much self-quarantined myself for the past two weeks
                  Completed in the past two weeks
                  • Beisan VANOS rebuild w/anti-rattle kit
                  • Valve adjustment
                  • Oil pan gasket
                  • New motor mounts
                  • PS fluid flush
                  • Thermostat replacement
                  • New cowl
                  • Hardwired dashcam
                  To-do
                  • Subframe reinforcement (sending the car out to my mechanic for this)
                  • 996 BBK conversion (fronts only for now)
                  • Paint correction
                  • Ceramic coat w/Kamikaze Miyabi
                  • Fuel filter replacement
                  • Trans flush
                  • Diff flush
                  • Clean up my Toyota Tacoma daily
                    Just ordered the Sony XAV-AX5000 kit from Enfig to replace this horrible Android HU.
                    2003.5 BMW ///M3 6-speed
                    2019 Jeep Grand Cherokee Trailhawk
                      Oil Change and get rid of the moldy smell coming from my vents.
                      2004 E46 Imola Red M3 Coupe
                      2015 F56 Pepper White Mini Cooper S
                      2018 W205 Polar White C300 AMG Night Edition
                        Seat leathers are autoberry, headliner material is from Veteran Company in CA.
                          Done so far:
                          • E21 trans mounts
                          • Trans fluid flush
                          In progress:
                          • Fixing the sandblasted front of my car (lots of rock chips from 100k miles in a rocky soil environment, pre-installed to my ownership)
                          • Full paint correction
                          • Ceramic coating
                          To do:
                          • Replace flex joint/giubo
                          Here area few photos of the rock chip repairs - not perfect but way better.
                          Build Thread
                            Still on Ohlins, yep.
                            Haven't settles on which LEDs I'll be running, yet.
