Originally posted by Cubieman
View Post
Multiple misfire error
I thought I might do a vanos test letting it idle, but without driving the car it won't really adapt to anything, from what I understand it sounds like I need to reset/view adaptations and THEN do the vanos test.Originally posted by Icecream View Post
Did you mean adapt? You can try it and see. Won’t hurt anything, worst case it will sit there and say not adapted. I think oil temp needs to be up so up to you if you want to idle long enough to see.
I don't want it to sit and idle for that long so it'll just have to wait til I can drive it.2004 Silbergrau Metallic 6MT
It will adapt without driving, you need to let it idle and once up to temp rev it a couple if times, no meed to rev to the limiter, just wot to different rpm levels. We just did this on a Z4M and it did adapt.
you can reset adaptations in INPA, it will show 0 as the adaptation value, and then after a few revs it will display the new values.
if you read your values before reset you will see where you where before and then an after to see how much better you are after the service
Thanks, I didn't run it long enough to get up to temp., nor did I rev. it hardly at all, this was likely the issue on it not adapting from the sounds of it.Originally posted by maupineda View PostIt will adapt without driving, you need to let it idle and once up to temp rev it a couple if times, no meed to rev to the limiter, just wot to different rpm levels. We just did this on a Z4M and it did adapt.
I did take note before clearing adaptations and am hoping all is well with my cam offsets in the end, I had a hell of a time getting engine timing correct, but it all finally fell into place.2004 Silbergrau Metallic 6MT
