Hey Guys,
I purchased CMS brackets a while back to do the 996 Brembo swap on my M3. I've had everything stored away and will be getting around to installing them in the upcoming weeks and need to order the pads. I had everything saved on the old forum but that's clearly useless.
I will be running the calipers with the factory 325mm rotors and wanted to confirm the make and model of the Porsche that I need to order the pads for. Was it 2006 Cayman S Front pads I need to use for the front and rear or was it 2003 Carrera pads I need to use? Lots of info on the 345mm rotor set up but I can't seem to find or remember where the info was for the 325mm set up.
If anyone can confirm, that would be great!
Cheers.
Cheers.
