Hey everyone. Been a while since I have posted on here. My engine blew. Got it rebuilt (machine shop held it hostage for like 7 months). In that time I got covid, school started again, and I was busy with work. M3 got put to the back of the list but as it is warming up I am more motivated to finish! Plus I keep seeing e46 m3's around and want to drive mine
Anyway... I have lots of experience with this car but it has been nearly a year since I last took it apart. I am in the re-assembly process and am noticing that im missing some trans bolts
You can see I have attached a photo of the bolts I do have.
According to Realoem I need
-3x M8x50
-2x M10x65
-2x M12x50 23001222891
-2x M12x90 23002282241
So right off the bat I clearly have the 3 M8 bolts. Check. I have 1 of the M10 bolts. So I will order another one of those.
But I am left with 2 matching, gold, m12 bolts. They appear to be the same length as the m8x50 bolts and slightly shorter than the m10x65 so I will assume they are 50mm.
However, when I look up photos of the M12x50 P/N I get a completely different bolt. It is a grey bolt with a large shoulder similar to the m10.
When I look up photos of the m12x90 I see gold bolts and a small shoulder similar to the ones i have... but the ones I have are def not 90mm.
I feel like a complete dummy right now... can someone please point out what im doing wrong and what I need to order? I am so lost. Thank you!
Real OEM link for context
-3x M8x50
-2x M10x65
