So for the Ohlins, 3DM is recommending a 7" spring for the 300 pound rate I want to run in the front. You guys have me worried that it won't get me the travel I need or the recommended height of 13.5.
Anyone have first hand experience with the 7" 300lb spring rate?
Where does 10% come from?
I went back and looked at my emails. The full story is that Ohlins says up to 20% is fine without a revalve but that will eliminate any potential for adjustment. I'd rather keep the adjustment as that's a big feature of coilovers to begin with.
I have. He claims you can run 300# springs with the stock valving, but I've talked to someone else who says otherwise. While I trust Barry is familiar with the R&T kit, 300# vs 400# is pretty far out of the 10% (or even 15% if you want to stretch it) rule of thumb for valving.
If you assume you can get away with rates within 10% of the original valving, I could get my fronts valved for 275 and run anything from 250 to 300#.
Originally posted by LVMESM46 View Post
Have you spoken to Barry @ 3DM about that? Im curious his thoughts and he offers the free revalve which you can take at anytime.
Originally posted by r4dr View PostLooking back at the R&T setup with lower front rates -- I've confirmed the struts will need a revalve for the struts to run something in the 250-300# range. I'm thinking about having them revalved with 275# as a target, because I should be able to run anything from 250 to 300 for that.
Since it's a 100% street car, I'm going to target something in the 1.16-1.20 range F to R.
Ah, true-- the B4s are twin tubes, like the Konis. I assumed you mean the monotube Bilsteins.
Every B4 car I've driven has felt very floaty, but I've never actually tried them paired with flat ride. I could see that addressing the floaty problem.
In comparison to what kw v2’s or BC coilovers feel like, this b4/eibach/hotchkis setup feels immensely better in every measurable way.
I’ll reiterate, this is not a track focused setup, but a great GT setup that also works well for a casual HPDE event or even a spirited canyon drive.
Had I decided the m3 was a better hpde chassis than the ap1, I’d have gone down the KW CS w/ flat ride springs, or just paid the piper and done FC’s modified bilstein’s.
The b4’s ride much better than the koni yellows have. Perhaps you mean b6’s/8?
The bilstein dampers ride worse and have worse travel. They're not "better" than the Konis. The do handle better, but they ride worse and are in the bump stops sooner, all else equal.
For a DD, I think the Konis are a better shock. For a weekend car, I think Bilsteins are a better shock.
... which is why my DD M3 (the wagon) and e39 M5 is on Konis and my weekend M3 (the coupe) is on Bilsteins.
Mayan was asking and kw or koni. Sure if you open it up there are many more options. I mean... What about stock? When's the last time someone drove a fresh stock setup? It's actually pretty good. Most of us think it sucks because we're just driving old clapped out cars lol
Why run Koni’s at all? The logical option is to run neither Koni or KW 1/2. Neither damper is ideal, where as either Billy damper is going to be good, depending on if you’re okay with the harsher b8 ride.
I have run the Koni/Dinan setup for 40k some-odd miles. At first I thought it was the most incredible thing I have ever felt. With experience and knowledge I have learned that they aren't so hot - for a few reasons.
-They lower the car without increasing the rate enough. In the rear, there is a moderate spring rate increase and switch to linear rate, but in front they only slightly increased the rate, while lowering half an inch. This is enough to practically ride on the bump stops at static height. I don't believe in running on the bump stop during normal use, as it gives the car a weird feeling. It feels harsh on bigger impacts and becomes bouncy during hard cornering. Linear springs are more predictable and easier to tune for damping.
-The shocks don't make enough compression damping. As the pace increases you can really feel the loss of grip and control. They are fine for street driving/commuting I suppose.
-The rear shocks being "compress to adjust" rebound adjustment is the worst f-ing design I have ever come across. If you must, then AT LEAST get the top-adjustable ones.
The Koni vs KW V1 is not a reasonable comparison because the V1 are non adjustable. Adjustability is nice to fine tune. You can get 90% or even 95% there, but having the ability to add or subtract a few clicks from the target setting lets you dial it in to your preference. The correct comparison would be the KW V2.
Both shocks are twin tube architecture.
KW are shorter and will allow lowering without risking crashing into the bump stops. Koni should be run at stock height since they are the same length of stock shocks.
I would do Koni with stock springs or KW V2.
