That's not too bad at all, good cleaning. But no, I wouldn't leave that rust.
Battery Tray in OK shape?
me personally i would still treat it. Looking at it post-clean up, i would approach it differently now.Originally posted by eforty6_m3 View Post
Correct...gray primer.
Here is how things currently look after removing the black tray, vacuuming out the area and cleaning up the rest with All-Purpose Cleaner and some towels:
Wondering if I should I leave it, as is. Is it overkill to use some wire brushes to get rid of the remaining rust and perhaps treat the area and primer it? Thoughts?
I would just hand sand the rust spots, and prob treat it with some anti-rust primer and call it a day. I'm not sure a wire wheel would be needed just yet.
Def keep an eye on this though, as we all know how cancer rust can get.
I’ve used this stuff too, but it gets gunky and messy. It’s good for preventing rust by spraying the undercarriage with itOriginally posted by eacmen View PostI’ve heard good things about https://www.fluid-film.com/
Ended up using the POR-15 starter kit to address my rust.
Happy to report that the unexpected battery compartment/tray rust project is now complete. Using a combination of wire brushes, wire wheels, roloc abrasive discs, sand paper, dremel grinding bits and patience, I was able to achieve this final result (with brand new OEM battery tray installed):
I just need to add the 2 plugs (the original ones I ordered were the wrong size, so new ones should be arriving today) and this project will be 100% complete and in the rear-view!
Pretty pumped that the Coastal Grey Rust-Oleum Satin Protective Enamel topcoat did a fairly good job of matching the existing grey in that area! Again, NOBODY will ever see this, so it was more for me, but I'm happy with how it came out. Here are some progress shots I took (excuse the crappy lighting) along the way:
After POR-15 Cleaner/Degreaser and Metal Prep:
After 2 coats of POR-15 Rust Preventive:
After 2 coats of aforementioned Rust-Oleum Coastal Grey Topcoat:
A reminder of before/after:
2005 BMW M3 (6MT) Instagram
2021 BMW M340i
- Likes 5
That looks great! I gotta check on mine now lol2004 BMW ///M3 Carbon Black/Cinnamon 6MT
2005 BMW ///M3 Interlagos Blue/Black 6MT Dinan S3-R
This thread made me check on mine too. Found some very slight bits of corrosion where the black bracket contacts the sheet metal. Ground those down to bare metal and added a layer of por 15. Problem solved.
Now just need to stop being lazy and finish fabricating the cover for my vincebar, so that I can give my whole trunk a layer of color matched paint.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Thanks for all the kind words, folks!
2021 BMW M340i
OEM #41007140848 (20mm)Originally posted by Dripdrop View PostDo you remember what plugs go into the battery tray area looking to get some but can’t seem to find which ones goes there
2021 BMW M340i
