If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Anyone know if the Turner Street Camber Plates will work with the TC Kline SA kit? I would really like to use something designed specifically for the street.
Yes, if you get 60mm perches with them. I think someone just linked the perches, by themselves, from Turner if you already have the plates and need a different perch. Over $100 for the perches and $450 for the plates. I'd look at GC street to save $100, they're really trick. I do like my TMS street plates though, but I plan to get GC next.
If waiting is an option, consider setting some cash aside and going for DAs that come packaged with camber plates. You will not regret it. Of all the mods that I have gotten for my car, DAs were the best mod by far. I only drive my car on the street.
For a non tracked car, still better to get street plates with the DAs.
I'm not a super big fan of TCK's plates in generals-- not a design that's easy on the shock towers and no thrust bearings.
Thanks.
I could swing the DA's but I doubt I will see the benefit on the street. I am hoping to get some adjustment advice from TC Kline and then leave them alone!
The SA's do include camber plates, but they do not look particularly street friendly either. I have heard that E36 top hats are an option. If so, is it a good option and would I need E36 M3 top hats, or standard E36 top hats? What else would be required to make them work?
Thanks for pointing out the GC option, T. I was unaware they offered a street friendly option.
