So I have a weird issue. It appears that my car is misfiring only after it has been idling for 10-25 minutes. When it happens, I can feel it the car shaking and the engine having some issues when I rev to 1200 - 2000 RPMs. No warning lights pop up on the dash when this happens. I borrowed my friend's ECS/Foxwell Diagnostic Scanner yesterday and cleared all the diagnostic codes that were stored previously. I drove around normally for an hour or so last night and did not experience a misfire. I scanned the car this morning regardless and the only code that popped up was an unrelated "20 IHKA: AUC heating" code for the A/C.
So I drove around slowly and let the car idle for 5-10 minutes at a time for about 45-60 minutes this morning. The misfiring happened during this session. Again, no warning lights popped up on the dash and the misfire was typically felt between 1200 - 2000 RPMs. The diagnostic scanner read out that all cylinders were misfiring. Here are all the codes that popped up in the "1 Engine-DDE Diesel Electronics DDE3.0" Auto Scan section:
- CD. DME: Misfiring, cyl 1 without cylinder cutout
- CE. DME: Misfiring, cyl 2 without cylinder cutout
- CF. DME: Misfiring, cyl 3 without cylinder cutout
- D0. DME: Misfiring, cyl 4 without cylinder cutout
- D1. DME: Misfiring, cyl 5 without cylinder cutout
- D2. DME: Misfiring, cyl 6 without cylinder cutout
- D5. DME: Misfiring, several cylinders without cylinder cutout
