Size of Vanos piston cap O-rings?
    Anyone know the size of these particular o-rings? If not, anyone know where I can buy just the piston cap o-rings? I have a small leak on one of them. Thanks.
    They’re part of the Beisan seal kit.
      I understand this...question still stands on actual size of the o-ring pictured here.
        I think the implication is that you can email Raj @ Beisan and see if he will tell you and/or buy just those o-rings from him.
          Point being, even these guys like Beisan and Dr. Vanos are sourcing them from somewhere...probably for pennies on the dollar. Not trying to spend $20+ for a couple of $2 o-rings if there are other options. I suppose I can just remove my current o-rings and take some measurements, but was hoping to avoid that.
            They almost certainly slightly exotic, e.g. vitron.
              Even if you find a supplier like McMaster or similar the MOQ is going to kill any potential savings.
              Unless you plan on reselling kits yourself raj is probably the most economical source.
                They are metric, 32x2.
                  Thank you! Did some searching and was able to find some already. 👍
