Interest in Supersprint V1 & V2 headers
This topic is closed.
I would be interested in the V1 stepped headers + Oversized (2.5") catted Section 1. Thank you Obioban for the explanation. Will stock Section 2 work with Oversized (2.5") catted Section 1?
For a baseline comparison, what power levels does the stock, resonated section 2 becoming a limiting factor?Originally posted by Obioban View PostSection 2:
1) Single tube unresonated. Good till ~300whp. Light.
2) Single tube resonated. Good till ~300whp. Light.
3) Twin tube (2.5”) unresonated. Good till ~400whp. Heavier.
4) Twin tube (2.5”) resonated. Good till ~400whp. Heavier.
With section 1 cats and section 2 resonators, does Sport still drone a noticeable amount?Mufflers:
1) Street. Similar volume to stock, but nicer tone. Zero drone. 2 lbs lighter than stock.
2) Sport. Louder, drones. 15 lbs lighter than stock. Probably the volume level than most people looking for an aftermarket muffler desire.
3) Race. Fuck you loud, drones. 25 lbs lighter than stock.
All mufflers above can be custom ordered in 2.5" internals. This is only beneficial for all out builds (not the normal cam/airbox/exhaust builds). Does add some weight. If you're doing this, you can also custom order a twin tube section 2 to match, so that it doesn't neck down where they join.
Notes:
-Street, sport, and race mufflers all flow identically.
-resonators also don't impact flow.
-if you want to eliminate drone, you need cats and resonators.
The twin tube section 2 does quiet things down a little bit. The resonators doesn't really change volume so much as tone.Originally posted by Sid_E46 View Post
From your experience, the resonated twin-pipe section 2 makes the exhaust quieter right? Does the non resonated keep the volume around the same level as the stock section 2?
From your experience, the resonated twin-pipe section 2 makes the exhaust quieter right? Does the non resonated keep the volume around the same level as the stock section 2?Originally posted by Obioban View PostI'm going to attempt to summarize the entire SuperSprint line to clear up confusion...
Section 0 (headers):
1) non stepped headers. These were the first SS e46 M3 header, and are what basically every good ebay header is a copy of. They're fine, but there's no reason to buy them since SS's released their step header line.
2) V1 stepped headers. These are the best headers on the market for the car. They make some of the most peak power and do so without trading off the midrange or bottom end. But, they require a bespoke section 1 to work (adds cost).
3) V2 stepped headers. These are also stepped but, shorter and not oversized. They don't have the peak power potential of the V1s (which really need cams and airbox to be fully realized), but the are still good in the bottom end and middle range. Works with any section 1, including stock
Section 1:
1) Normal sized catted. Works with any normal sized header (not V1s). Uses HJS cats, so holds up to the heat of track use.
2) Normal sized uncatted. Works with any normal sized header (not V1s).
3) Oversized (2.5") catted. Only works with V1 stepped headers. Uses HJS cats, so holds up to the heat of track use.
4) Oversized (2.5") uncatted. Only works with V1 stepped headers.
Section 2:
Mufflers:
Notes:
Section 1:
Section 2:
Mufflers:
Notes:
- Likes 10
Wrapping up the setup by this PM and having a final validation meeting with ECS - then it's a go. Shooting for end of PM or evening today.
I'm having trouble finding apples to apples comparisons when it comes to comparing Street v. Sport v. Race mufflers on YouTube.Originally posted by Obioban View PostIf you’re going to spend the money on SS, it’s kind of silly to not go V1. They’re the option that makes more power than other options on the market.
If you do that, you have to use the SS section 1. After the section 1, you can use anything on the market… though if you’re doing a full NA build, the oversized twin 2.5” SS section 2 is the move. From there, all supersprint mufflers make the same power— the differences are only weight and volume.
I'm looking for a sound comparison with Stepped V1s, Catted Section 1, Resonated Section 2 with each of the muffler types. Does anybody know of a video?
Does SS make a 2.5" unresonated sec 2? Perhaps this will allow you to retain the raspy motorsport sound.Originally posted by Dino View PostI’m 100% getting the SS V1 stepped, and the Sec 1 SS Catted. I’m now just debating if I should go with the SS twintube oversized 2.5” resonated section 2 or just stick with the stock Sec 2.
I have read Obioban’s review in the past saying that they clearly welcome a lot more power. My only concern is if it’ll drastically change the signature raspy sound of the E46 M3 that I would like to keep. If I recall correctly I remember reading Tbone saying that it made him lose the Motorsport sound of the M3 and went back to his old setup, but I believe it was straight piped and not the stock sec 2.
Can anyone who runs or ran this setup let me know how the sound changed or what not from the stock Sec 2, and if it’s worth it?
Thanks in advance, extremely excited this group buy is about to go live very soon!
Right now I have the SCZA exhaust along with AA headers, and it sounds great. Not incredibly loud or super quiet either. Will the SS section 1 (60mm) make my car sound too loud? Not really what I’m looking for. Or is it better to get the section 2 straight pipe (60mm)?
Thanks in advance, extremely excited this group buy is about to go live very soon!Last edited by Dino; 05-01-2021, 06:03 PM.
