How's the glare with those LEDs?
Having tried a good range of color temps for headlights, I think my favorite color temp range is something like 3500-3700 K. Above that, I feel like I start losing more to glare than I gain in resolution.
Automotive xenons are generally what, low-to-mid 4000s K? That's pretty much the highest I'll go for.
Black & Tan 332iT
Sounds like those are crap, because the stock headlights are not very good
Glad to hear the review, though, as I've been debating LED conversion to take weight off the nose.
Minor updates:
The mullet is on v31 now, and thanks to karter16 and all his work, we've got cold start all dialed in now. It was honestly close before but it's pretty on the money now. Plus, Heinz's car now runs right on the same file as mine and the three beta testers on the file are all reporting positive results. We did something good. If you're on an existing one and want the latest, reach out and I'll whip a new file up for you.
Second, I've had a broken-mount passenger headlight for as long as I've owned the car. I finally picked up a replacement and decided to do the NHK LED headlight conversion using nextelbuddy's great DIY video (thank you!) with some minor tweaks. The two tweaks:
1) Doubled up the wiring to the low beams (red+green to positive, black doubled-up to negative) as the wire gauge in the BMW wiring is not quite large enough for the LED headlight wattage. It's fine in the HIDs because the bulb itself runs at higher voltage and therefore lower current.
2) I 3D printed plastic ballast replacements to drop the dead weight that would otherwise be sitting there. Overall I think I dropped 3lbs off the nose.
Honest opinion, I'm not in love with these lights. Yes they're WAY brighter but the color temp is bluer, so they seem less effective with the light output to me. The cutoff is also super weird - it's like a step _| instead of a ramp _/. Not super into it. Not so much that it's worth removing them, but I wouldn't do it again. The stock headlights were pretty damn good.
Also, a 55" TV fits great even with the brace left in place:
- Likes 7
Many thanks.Originally posted by Bry5on View Post
I had to use spacers with my SS exhaust too, it fits very poorly. Reused the same spacers with the cabrio brace, no issues there, although I made these spacers myself, so I can’t comment on the SS specific hardware.
I had to use spacers with my SS exhaust too, it fits very poorly. Reused the same spacers with the cabrio brace, no issues there, although I made these spacers myself, so I can’t comment on the SS specific hardware.Originally posted by D-O View Post
I had to use the spacers included with my SS exhaust to get the braces to fit properly with the oversized pipes. Any idea how the convertible brace would work with the SS oversize dual pipe section two?
I had to use the spacers included with my SS exhaust to get the braces to fit properly with the oversized pipes. Any idea how the convertible brace would work with the SS oversize dual pipe section two?Originally posted by Bry5on View Post
Fits great! Rough math says that the 4 cabrio fasteners will see about 60% of the load of the original 8, and this brace will certainly be stiffer inherently. So an upgrade on paper. No real noticeable change, but it's definitely not less stiff. It's getting hard to do the driveway test as the car isn't making much creaking in the door sills unless it's pretty extreme.
Funny, this is actually what I started on, which led me to the project I chose instead! I went to visit George to grab a scan of that area to design a brace just like that.Originally posted by enjoy_m3 View PostWow, thanks for your contribution Bry5on, great read and development! I know there's a guy in europe selling a brace that bolts the shock tower and fender rail. Do you think that would add even more rigidity?
https://drifthq.com/products/tech-53-bmw-e46-bolt-on-strut-tower-reinforcement-kit?pr_prod_strat=e5_desc&pr_rec_id=64e6463eb&pr_r ec_pid=8087369875643&pr_ref_pid=8006405423291&pr_s eq=uniform
It just so happened that the car I was scanning had hit a big pothole on one side so I could see exactly how the metal deformed. Once I’d given that a good look, I was pretty convinced that the flexiness that cracks that strut tower seam sealer is actually coming from where I braced, not directly from where the cracks were forming. So we ran the experiment I posted about earlier to validate the theory. At this point, I think that the brace above would be a bit redundant. I’d bet it would provide incremental gains, but likely much smaller than the invisible ones I installed. Plus, it wouldn’t be invisible
So for now I’m pretty happy with where it is.
- Likes 4
The E46 front strut towers are known to be out of shape, it is one of the car’s weakest point. When the strut towers start to “mushroom,” it means that the metal has begun to deform. It is a result of stress, corrosion, or improper load distribution. This E46 strut tower reinforcemenent kit is the easiest way to fix orLast edited by enjoy_m3; 07-01-2025, 02:10 PM.
From a stiffness performance perspective, technically yes although I’d wager you’re capturing 99.9% of the value with just fasteners. I think on balance you could make an epoxy/rubber joint a little lighter though. Given that I don’t actually know the loads here, tough to say!Originally posted by karter16 View Post
I wonder if there would be additional benefit to be gained by epoxy bonding these? (3M 73333, etc.) I'm not really sure if there's any risk of movement over time around the bolt holes?
I wonder if there would be additional benefit to be gained by epoxy bonding these? (3M 73333, etc.) I'm not really sure if there's any risk of movement over time around the bolt holes?Originally posted by Bry5on View Post3) I got to installing the fender brace with these awesome new rivet nuts (definitely recommend).
Installing with wet POR-15 or is that an epoxy? Thank you for all you do!
These bad boys, installed in a .5” hole: Metric Low-Profile Rivet Nut, Tin-Zinc-Plated Steel, M8x1.25 Internal Thread, 15.2mm LongOriginally posted by karter16 View Post
I'm very excited for this! Having felt some extra chassis rigidity with the rear brace I now want as much as possible! I love that this solution is entirely invisible when installed! Which rivnuts did you use? (Or have I missed that somewhere?)
Thanks very much for sharing the sendcutsend cart!
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
Don’t do what I did and accidentally go one step too far with your stepped drill bit on the first test hole! But if you do want a low risk ‘test’ hole, the topmost one does the least structurally.
- Likes 3
I'm very excited for this! Having felt some extra chassis rigidity with the rear brace I now want as much as possible! I love that this solution is entirely invisible when installed! Which rivnuts did you use? (Or have I missed that somewhere?)Originally posted by Bry5on View PostOk, great successes!
1) Last night I loaded karter16's custom binary that logs extra values over CAN. So far it's working great, even with extra data like lambda integrator, and now I can finally stop bothering the D-bus constantly while I'm driving. Thank you! Datalog of a drive here: https://datazap.me/u/bry5on/kartercan-log?log=0&data=23
2) Today I installed v2 of the exhaust brace. I'd noticed around 3300rpm that a bit of vibration was still coming through, so I modified the design to use the non-m e46 exhaust hanger bushings. Mild-but-still-there improvement. I also discovered that the thin brace to the exhaust has cracked. I guess next time I'll try Ti or just design a weld-on bracket.
3) I got to installing the fender brace with these awesome new rivet nuts (definitely recommend). Fitting up:
Rivet nuts installed:
Bolted in:
After installing the brace, I repeated the earlier experiment but as below with the car 1) in the air and 2) lowered straight on the ground. I left the Slon brace installed for the most conservative test. Measuring displacement here I saw .001"
So what's the verdict? A nice improvement again! The front feels in line with the rear now after the recent work I did back there, and so far it's most noticeable on pothole and sharp road impacts. There's less harshness and the steering feels almost a bit lighter. There's yet another step of less vibration in the steering wheel when driving over not-smooth pavement, although not as drastic a change as the Slon brace. I expect that once I get a chance to put the car through its paces, it'll be even more stable and consistent during cornering, putting the suspension to work instead of the chassis.
If you want to order/recreate this on your own car, click this link and get a set for yourself! https://cart.sendcutsend.com/chn7orju3zid The job took about 4 hours and involves removing the bumper, headlights, fenders at the very least. So budget for a full day as I work pretty fast.
edit: the cart above is for two sets. Either reduce the quantity to 1 each or get one for a friend!Last edited by Bry5on; 06-21-2025, 04:13 PM.
- Likes 10
