Originally posted by Bry5on
All of the red locations look like they'd be fair game in the sense that the bolts wouldn't run into anything in the chassis:
Blue spots would land under the cowl, like Bryson said. Maybe some (big) rivets in these spots would be low profile enough to not interfere with the cowl? You definitely want fasteners up front though, that's the part of the mount that most wants to peel away from the chassis.
If you're going through the effort of redesigning for bolting, I would be inclined to attempt a sheet metal version. You don't need material along the top if you're not bonding, so a "sideways J"-shaped piece might work (maybe add a couple weld-on ribs for extra strength). The resulting parts is probably gonna be similar weight, but should be much cheaper to produce.
Give me a sec, let me draft up something real quick, just to explain the idea better.
Edit: Super rough, but something like this:
Maybe rotate the ribs inwards a bit to have them be more in line with the loads.
Here's the machined version overlaid, for reference:
Just shoot a few strategically placed holes through it - although I think one of those holes would have to be right under the plastic windshield cowl which is not super great.
