2001 M3 Journey: Laguna Seca Blue Edition
    Car looks great. 18x9.5et35 is a more conservative solution for the front. It doesn't look like Titan7 makes that offset. What do you think about the Apex ec7-rs? I know Apex wheels are a dime a dozen on the forums but they offer way more size/offset options.
    On another note, I find 19s to be fine comfort wise on the street with my ohlins setup. Dallas, particularly where I live, has atrocious streets. Wheels are OEM ZCP. I imagine I am giving up some ride comfort but they look so good!
      Thanks for the feedback. Sometimes it takes a couple tries to get things right.
      I have to say those e90 ZCP's look reeally good! If I can't get a hold of some CSL fronts I will consider these. How do you find the ride with 19's vs 18's?
      My car came with the 19in E46 ZCP wheels so I don’t have any 18in ride comparisons unfortunately. I’m not sure where you are in CA but you’re welcome to come by my place and try on my wheels (staggered style 163M) to see if you like them for your car.
        Yeah they got back to me unfortunately there's no solution. I'm at least able to offer my feedback for future consideration.
        Contrary to me liking TS7's I don't really like the EC7's. Arc 8's are certainly a consideration. I agree either a higher offset or 18x9 would be a better solution.
        ​Appreciate it! I'm up in Bay Area.
        🔹 2001 M3 Laguna Seca Blue
        Instagram: link
        Build thread: link
          Another update.
          After driving my car so little and neglecting the battery it was all but gone even after charging. This was the perfect opportunity to shed some weight. While some of the OE sized lithium solutions were nice, the price not so much.
          After finding good feedback on the Antigravity ATX-30RS I found one for a deal($350 on Amazon direct from Antigravity).
          Additional parts required:
          -Adapter posts: link
          -Battery hold down: link
          -J hooks(will double check length): link
          Click image for larger version  Name:	IMG_0676.jpg Views:	0 Size:	92.0 KB ID:	289739
          Click image for larger version  Name:	IMG_0809.jpg Views:	0 Size:	71.2 KB ID:	289740​
          First test fit the battery to see where to mark the holes for the J hooks.
          Click image for larger version  Name:	IMG_0697.jpg Views:	0 Size:	117.2 KB ID:	289741​
          These trays are common across non-M's. So no need to feel bad drilling and hacking it up. I decided to also remove the hold down bar. These are assembled with, go figure, more spot welds!
          Click image for larger version  Name:	IMG_0834.jpg Views:	0 Size:	132.2 KB ID:	289745​
          Click image for larger version  Name:	IMG_0835.jpg Views:	0 Size:	141.8 KB ID:	289742​
          I found my spot weld bits from the gusset cup reinforcement and had it off without any fuss.
          Click image for larger version  Name:	IMG_0836.jpg Views:	0 Size:	238.2 KB ID:	289743​
          Test fit again, then trim the J hooks so the battery beauty cover can fit.
          Click image for larger version  Name:	IMG_0837.jpg Views:	0 Size:	192.9 KB ID:	289744​
          Full assembly weighted.
          Click image for larger version  Name:	IMG_0838.jpg Views:	0 Size:	141.5 KB ID:	289746​
          Old weights minus the battery tray.
          Click image for larger version  Name:	IMG_0617.jpg Views:	0 Size:	110.6 KB ID:	289747
          Click image for larger version  Name:	IMG_0619.jpg Views:	0 Size:	63.8 KB ID:	289748​
          Very clean installed, and the beauty cover/tray fits no problem.
          Click image for larger version  Name:	IMG_0842.jpg Views:	0 Size:	265.4 KB ID:	289749​
          While I was in the mood I also removed this goop dispenser for some bonus weight.
          Click image for larger version  Name:	IMG_0618.jpg Views:	0 Size:	61.0 KB ID:	289750​​
          I'm able to use my Noco Genius 10 to charge on Lithium mode. This was approved by Antigravity. Too soon to tell how long it will last, but this is pretty good weight saving for the $.
          Afterwards I got an alignment on New years eve, and took it out to the mountains the next morning to find many others with the same idea. With the new wheels and junk out of the trunk the car really flys. The Ohlins are the real deal.
          ​​Click image for larger version  Name:	IMG_0799.jpg Views:	0 Size:	295.7 KB ID:	289754
          Stay tuned as there is much more to come!
          Instagram: link
          Build thread: link
            Great review on the battery
              Very nice build
                ​Starting the exterior restoration.
                Focus is now getting the exterior restored. All the faded plastic bits, front clip parts, yellowed lighting, roundels, paint correction. Everything had to come out.
                Faded cowl and wipers.
                Click image for larger version  Name:	IMG_0903.jpg Views:	0 Size:	91.0 KB ID:	299351​
                Click image for larger version  Name:	IMG_0904.jpg Views:	0 Size:	74.9 KB ID:	299352​
                Yuck
                Click image for larger version  Name:	IMG_0906.jpg Views:	0 Size:	69.3 KB ID:	299353​
                Click image for larger version  Name:	IMG_0905.jpg Views:	0 Size:	62.4 KB ID:	299354​
                Headlight dissassembly is a paint for those with headlight washers. So much dirt.
                Click image for larger version  Name:	IMG_0910.jpg Views:	0 Size:	160.6 KB ID:	299356​
                All lighting is getting replaced/restored where needed. This gave me an opportunity to restore the inner trim.
                Click image for larger version  Name:	IMG_0977.jpg Views:	0 Size:	128.8 KB ID:	299361​
                Front bumper had to come out to get to the grill. Front clip trim, and front aux fan had to come out for cleanup.
                Click image for larger version  Name:	IMG_0929.jpg Views:	0 Size:	161.4 KB ID:	299355​
                Click image for larger version  Name:	IMG_0922.jpg Views:	0 Size:	149.7 KB ID:	299357​
                I'm trying to be less wasteful on replacing parts that function well as is. So I decided not to mess with the condenser as it was it fine condition.
                Got creative.
                ​Click image for larger version  Name:	IMG_0931.jpg Views:	0 Size:	135.6 KB ID:	299358​
                You all laugh, but it worked great on the oil and ac condensers.
                Click image for larger version  Name:	IMG_0933.jpg Views:	0 Size:	170.4 KB ID:	299359​
                Looking much better. Lot's of degreasing and trim restorer.
                Click image for larger version  Name:	IMG_0978.jpg Views:	0 Size:	193.9 KB ID:	299360​
                Trim parts went through the same process as previous trim. Lots of SEM trim black.
                Click image for larger version  Name:	IMG_0989.jpg Views:	0 Size:	260.9 KB ID:	299362​
                Re-assembling the front clip trim
                Click image for larger version  Name:	IMG_0991.jpg Views:	0 Size:	206.8 KB ID:	299363​
                No more dirt or faded parts. Might seem crazy to do this, but these parts show through the grills and bumper. It's all in the details!
                Click image for larger version  Name:	IMG_1046.jpg Views:	0 Size:	172.3 KB ID:	299364​
                Reassembling the headlights with freshly restored trim.
                Click image for larger version  Name:	IMG_1051.jpg Views:	0 Size:	131.5 KB ID:	299365​
                New new
                Click image for larger version  Name:	IMG_1053.jpg Views:	0 Size:	142.0 KB ID:	299366​
                Click image for larger version  Name:	IMG_1054.jpg Views:	0 Size:	163.7 KB ID:	299367​
                Crazy difference.
                Click image for larger version  Name:	IMG_1057.jpg Views:	0 Size:	139.8 KB ID:	299368​
                Click image for larger version  Name:	IMG_1058.jpg Views:	0 Size:	242.7 KB ID:	299369​
                Lighting install will have to wait however. With most of it and external trim still removed, I realized it made sense to take care of the paint correction.
                I had a lot of this equipment around but hadn't set aside the time for it yet. Little did I know how much time I would spend on it. I'll get into this in the next post.
                ​Click image for larger version  Name:	IMG_1150.jpg Views:	0 Size:	71.2 KB ID:	299370​
                Instagram: link
                Build thread: link
                  Paint correcting.
                  This is the first time I've gone into the a deep invested paint correction. I was a little surprised by how long it took, but I got used to it and took my time. The process took 1-2weeks working when I had time, and not too late to avoid pissing off my neighbors.
                  I would say about 20-30hrs invested. The results were dramatic.
                  First step was stripping off all the old.
                  Click image for larger version  Name:	IMG_1093.jpg Views:	0 Size:	110.7 KB ID:	299755​
                  Griots DA polishers were used with orange pads paired with Sonax CutMax, then black pads with Sonax Perfect Finish.
                  Click image for larger version  Name:	IMG_1245.jpg Views:	0 Size:	151.7 KB ID:	299743​
                  Prep was easy with all the lighting and trim removed.
                  Click image for larger version  Name:	IMG_1246.jpg Views:	0 Size:	125.8 KB ID:	299744​
                  Click image for larger version  Name:	IMG_1251.jpg Views:	0 Size:	134.1 KB ID:	299749​
                  Perfect time to do the LED tail light swap too.
                  Click image for larger version  Name:	IMG_1240.jpg Views:	0 Size:	119.0 KB ID:	299746​
                  First pass. The CutMax is crazy good and practically looks finished already. It does haze over though which is normal.
                  A good tapeoff comparison.
                  Click image for larger version  Name:	IMG_1263.jpg Views:	0 Size:	45.9 KB ID:	299748​
                  So much glosss.
                  Click image for larger version  Name:	IMG_1179.jpg Views:	0 Size:	111.5 KB ID:	299745​
                  Click image for larger version  Name:	IMG_1356.jpg Views:	0 Size:	87.3 KB ID:	299747​
                  And "just like that" days later we're all done. I went back and forth on sealant, but decided on Collinite 845. Have to stay period correct amright.
                  Pictures uploaded here don't do it justice.
                  Click image for larger version  Name:	IMG_1196.jpg Views:	0 Size:	145.5 KB ID:	299750
                  Click image for larger version  Name:	IMG_1183.jpg Views:	0 Size:	92.2 KB ID:	299756​​
                  I'll post more pics in the next post where I'll cover the lighting and trim installation. Before that, I prepped the LED tail lights that would replace the old stuff.
                  These take to polish quite easily.
                  Click image for larger version  Name:	IMG_1353.jpg Views:	0 Size:	125.0 KB ID:	299752​
                  Click image for larger version  Name:	IMG_1354.jpg Views:	0 Size:	198.3 KB ID:	299753​
                  Bangin.
                  Click image for larger version  Name:	IMG_1358.jpg Views:	0 Size:	184.3 KB ID:	299754​
                  While this was all in-progress, OEM grills, reflectors, and "some other goodies" went off to the paint shop. Stay tuned!
                  Click image for larger version  Name:	IMG_1065.jpg Views:	0 Size:	217.0 KB ID:	299757​
                  Instagram: link
                  Build thread: link
                    Looks so good.
                      Man is spending cheddar and time.
                      Commendable.
                      2005 BMW ///M3
                      Black6MT Daily
                        Love the progress. It's giving me motivation to start working on mine
                          Being you replaced both headlight lenses, are you putting on Laminx or something similar over them? Is that even a thing for the E46's? I did it over a decade ago at least to the ZKWs on my E36 and it absolutely saved them many times.
                            This thread makes me want to ACT UP. Stunning work... Glad to know I can save all those crusty plastic bits with a good cleaning and SEM
                            2003 E46 M3 - Alpine on Imola Build Thread
                              0-60motorsports Sharocks Loopyspec Rokoz appreciate it guys!!
                              Grey Phox I went back and forth on this. They're easily replaceable lenses, so FCP warranty(and not tailgaiting semis) is the answer. I wasn't sure I could effectively apply PPF, it degrades, and you have to buy the material. With that said, look out for my next post where I'll cover what I did with the fog lights.
                              Instagram: link
                              Build thread: link
                                Fair enough. Luckily I got the pre-cut stuff, less hassle imo.
                                Looking forward to see what you did there. I'm not the biggest LSB fan but the car looks great and seems to be in more than capable hands. Nice work.
