  • Slideways
    Looking forward to your review on the headunit. Did you consider the "automotive grade" version? - https://xtrons.com/bmw-rover-mg-andr...b-rom-pe8246bl
  • karter16
    Originally posted by robgill View Post
    Just ordered the same unit. Going to try and use your splash screen!
    Nice one - I've very happy with it so far - better than I was expecting for sure.
    FWIW he's a copy of the splash screen sized to fit that unit.
  • robgill
  • 0-60motorsports
    Nice! My car has factory nav so I'll have to order the longer harness if i get this. Will wait for you to post more feedback before i decide. Cheers.
  • karter16
    Well that was easy!
    Mr 2 went to bed early so I had some time after dinner to swap the new head unit in.
    First up is removing the old head unit, the centre vents (the worst bit of the exercise), and the lower console bracket, so that I could install the HVAC relocation bracket.
    Console bracket out.
    How does so much debris get into a sealed area!!!
    The car had had a Parrot bluetooth unit installed, which never worked properly for me, so that had to come out. I was a bit worried about how the wiring for it might have been done. The wiring harness had in fact been cut to put the Parrot unit in series. Fortunately it had been done well and I was able to just unplug the Parrot harness and plug the OE harness back together. I'll tidy it up further in the future, but for now I've wrapped it with fleece tape and packaged it up.
    I then swapped the switch strip and cigarette lighter across to the HVAC relocation bracket (photo taken before swapping over):
    The Xtrons unit comes with an ISO wiring harness and it makes it ridiculously easy to connect the head unit. Just plug it into the Xtrons and plug it into the car harness and that is literally it. Everything just works. The ISO harness comes with some other tails for other harnesses. I intend to remove these connectors I don't need at some point in the future to tidy things up further, but before I do that I'll just run the unit for a while and make sure I'm happy with it.
    Once I'd done a quick test to make sure functions were working I put everything back together, and voila!
    It works.
    As others have noted the dash trim doesn't sit quite right. This appears to be because the clip is built into the Xtrons (see below) and it seems to be slightly too high up - a quick go with a file will fix this I think - again will get back to this over the Christmas break.
    Initial impressions of the head unit?
    • Ridiculously easy to install and get setup - you get a ton of wiring harnesses in the box and it seems intimidating. You only need the ISO one and it's entirely plug and play, no tapping to do, no extra wires to hook into, nothing. Just plug in the additional things you want (GPS, Wifi Antenna, etc. I didn't bother with the USB ports, 4G, etc. as I won't use them).
    • The unit is FAST. No delays anywhere, the UI is fast and responsive.
    • CarPlay seems good so far, I connected my phone via bluetooth and it just worked.
    The real test is going to come over the next few months as I see if it reliably works well and quickly, or if there are gremlins. Promising start anyway, will provide an update in a few weeks once I've used it for a while.
  • 0-60motorsports
    Well this arrived astonishingly quickly considering I ordered it on Sunday night and it arrived from Hong Kong this morning!
    Not sure what the quality of the product is like, but the delivery and sales service have been excellent.
    I went for the IX8246BHL which is the highest spec option for the E46.
    First impressions are better than I was expecting. It seems to be finished nicely, the buttons feel pretty good. The twisty knobs don't have the same inertia feel that the stock ones do, but they're pretty good. The chrome would usually annoy me but I'm kinda interested to see with the SMG whether the chrome on the knobs ties things together a bit.
    I feel a bit of a sense of inevitability about this venture as I have, for years, seen others complaining about their "China-sourced" head units, so if this doesn't work out I have only myself to blame.
    In the end I went with this option because I wasn't very enthused about the tier 1 manufacturers offerings, and secondly because this gives me a more modern unit without too much of the area taken up with buttons, but also without the "slab glued to the dash" look that a lot of other options have.
    As I said previously I'm very comfortable with the tech, so don't mind some fiddling to get it setup, but once it is it needs to be rock solid. Plan to give this a year to see how it goes and will re-evaluate then.
    Thanks for posting this. Let us know how it performs once installed. Might also get this.
  • karter16
  • karter16
    And now for today's edition of karter16's Random Side-Quests.
    On my to do list is the radio/nav. I've spent a lot of times working through various options and they all make me sad to some degree as there just aren't any options out there that give me the combination of OE-like and modern functionality that I'm looking for.
    The current trend in the E46 M3 world seems to be towards minimalism which is fine, but for practicality reasons I want to swap to a touchscreen nav setup that I can run CarPlay on etc. Ideally this looks OE-like, however having said that I'm not a fan of the dated "screen with buttons around it" arrangement that the original E46 nav had. Times have moved on with technology and it's unnecessarily pokey (in my opinion). That said I don't particularly want a big slab of a tablet stuck on the dash either. I'm currently tilting towards something like this Xtrons unit:
    This in itself makes me sad, as I would like to steer well away from the cheap electronics, but that said none of the main manufacturer's offerings enthuse me either. I'm inclined at this point to give the Xtrons a go. If it's rubbish/not reliable then I'll try something else instead. I'm technically competent so don't mind some effort to get things working well, I just need them to be reliable once I've got them setup...
    Anyway, back to my morning cup of coffee quest...
    Regardless of what option I go with, I want to make it feel as OE as possible. One aspect of that is replicating the original boot/splash screen used on the OE Nav. Now of course the OE Nav is more than 20 years old at this point and the original image is low resolution:
    I had a decent search on trusty google but was unable to locate a high-res reproduction of this image, so I decided to make my own.
    I actually used Figma to do this, which is a bit of a random choice, but I'm very familiar with it and its capabilities are more than sufficient for this project. Secondly Figma is a vector image tool, so what I'm producing here is a vector-based image which I can then use to output whatever resolution I like with no loss of image quality.
    Upscaling images by hand, especially graphics/text is part math and part subjective tweaking. To start with I take the source image, resize it to a suitable scale to work with on the canvas (I chose 1280w, large enough to see detail, without being too large and unwieldy). I then started overlaying the text and graphic components. When doing text I tend to use a contrasting colour so that I can get the sizing, etc. approximately right and see what I'm doing:
    Often the challenge can be working out exactly what font has been used. BMW made this nice and easy for me in this instance as they use their own "BMW Helvetica" font for everything πŸ™‚
    Once I figured out the exact size to set the font to, which is trial and error, I was then able to roughly put in the bars with the linear fades on each side. Getting the proportions of the fade right is again just trial and error and viewing at different zoom levels to judge what's right.
    I squared everything up and had an image that looked pretty much like the original, but higher quality. The next step is make sure it replicates the original as closely as possible which is a lot of tweaking and pixel shuffling. I find that the best way to do this is to take the image you've just produced and output it at the same resolution as your original image.
    This gave the the following:
    Looks pretty good huh!
    Actually when we look at the original and the reproduction side by side (repro on top, original on bottom) we can see I haven't quite got it right.
    In the reproduction the BMW text is slightly to the right. This is because I centred the text in the image between the fade bars which I made of equal width on both sides. Doing that on the face of it makes sense, but there's a good reason why BMW tweaked it slightly.
    If we look at this side by side (repro on top, original on bottom):
    We can see that BMW actually made the fade bars on the right hand side slightly wider than those on the left, this is to account for the fact that only the top right edge of the W extends fully to the right of the bounding box for the text, whereas the B on the other side is hard up against it. Although in my image the text is dead centre and everything is symmetrical, the perception to the eye is that there is more whitespace (or blackspace in this case) after the W than there is before the B. To account for this BMW actually made the fade bars on the right hand side come across to the left just a little bit.
    So let's adjust it:
    Getting closer, just a bit more to go:
    Now we're looking pretty good!
    It was a number of iterations to get to this point, but now things are looking pretty similar between the two. I'm happy with this now.
    All of that work means that I how have a fairly faithful, high res, reproduction of the original image ready to go for when I need it.
    This is pretty niche so I can't imagine anyone else really having any use for this, but if you do you're more than welcome - SVG and PNG downloads below :-)
    SVG
    E46 BMW Nav Splash Screen Vector.svg
    1280w png
    2560w png
  • karter16
    Originally posted by Avedis View Post
    Thanks for the link. If you shoot me your email in a private message, I will send you a copy of the tutorial. It isn't done, but the wiring portion of it is complete. I can also send you a link to the crimp tool needed for the MQS connectors used in the mirror plugs.
    Awesome thanks! Will PM now :-)
  • heinzboehmer
    Does the mirror switch go to the GM5? If so, why not depin the wires from that and make a new short harness to replace it with? Instead of having the harness go from center console to door and then back to center console
    Edit: Aaah wait no, I think it goes to the memory mirror modules. Carry on...
  • Avedis
    Yes sure,
    They're an AliExpress special - here's the link: https://www.aliexpress.com/item/1005...7063f19c7KXihb
    Key thing to note is that you have to bring up the picture for the item/s you want and then add to cart. On this page it's the male and female 6 pin black connectors.
    Note too that you'll need to cut the little wing off the black connector that plugs in to the mirror control unit so that it fits - trivial with a craft knife.
    Not for you specifically Avedis as have seen in your build thread you have the same control unit as me, but for others, check your mirror control unit first if you do this as if you have other mirror features you may have a different and/or second connector on your mirror control unit to wire in as well.
    Thanks yes I've been following your amazing build thread! I'd be keen to see some more photos of how you routed the wiring, but maybe that's coming in the complete diy guide you're putting together?
    Thanks for the link. If you shoot me your email in a private message, I will send you a copy of the tutorial. It isn’t done, but the wiring portion of it is complete. I can also send you a link to the crimp tool needed for the MQS connectors used in the mirror plugs.
  • karter16
    Nice, do you have a part number or link for those connectors?
    As you saw in my build, I recently did the install. I actually started something similar with the harness but changed plans last minute. If you need any info on the wiring/connectors/tools/etc shoot me a message.
    Yes sure,
  • Avedis
  • karter16
    Quick mid-week update - As I mentioned in my last update I haven't yet routed the wiring for the mirror controls to the centre console location. The reason for this is that I don't want to have to cut/hack into my wiring harness for a modification that I may feel differently about in the future. So that I can avoid cutting or tapping into the existing wiring I ordered some connectors so that I can make a harness extension that connects to the OE plug sited in the drivers door.
    These connectors arrived today:
    Now that I have these I can install an extension from the centre console to the door and put these connectors on each end and just plug it all together without any damage to the main harness 😎
  • karter16
    Really enjoying the restorative focus of this build. Awesome to see your dad helping you out, and your son being a part of it as well.
    As a father of two, it's hard not to get emotional when reading about your children's health struggles and long stays in the hospital. I'm sure that's incredibly draining on you and your family. I know it's just a car forum, but I hope writing it all out like that helped you unpack it a bit. I hope this project continues to be a healthy and positive outlet and counter balance the daily struggles.
    Thank you so much for your kind words and encouragement. Yeah it's been a long six years and we'll have more to go, but it's worth it all for the times when the boys are home and well and happy.
    It is just a car forum, but funny the places you find support and encouragement eh! Nice to have something fun to think about and work on for sure!
