Ross' Alpine White E46 track build
    Hi all! Checking in from Michigan, very happy to have this forum. I have a 2003 M3 in Alpine White which is almost exclusively a track-rat at this point. Purchased it around 2 years ago and have been building it up ever since. Currently used just for HPDEs, but working towards a Time Attack and/or NASA/SCCA class racecar.
    Happy to be a part of the new community here.
    Current build:
    Suspension MCS 2-way
    Hypercoil 2.25 springs
    Turner camber plates
    Bimmerworld Trackcab FCAB
    RevShift rear subframe bushings
    Rear subframe reinforcement
    Front subframe reinforcement
    BMW front control arms
    Rear Camber Arms
    Spherical Shock Mounts
    Adjustable Spring Perch
    Rear Camber Arms
    Apex Arc8 18x9.5 et 35
    Apex ec10 18x11 et 25
    Interior OMP HTE-R
    Sparco Evo 2
    Kirk Roll Bar
    Schroth Harnesses
    LED Light Kit
    Aim-2 Solo DL
    OMP 320
    Lifeline Quick Release
    MOMO Hub adapter
    Lifeline Fire Suppression
    Seat Sliders & Adapter Plate
    Engine K&N Intake
    Mishimotor Alum Rad
    Mishimotor Oil Cooler
    Mishimoto Electric Fan
    TrackSpec hood vents
    Exhaust
    Bimmerworld street/track exhaust
    Stock headers
    Stock Section1
    Transmission JB lightweight flywheel
    JB Clutch
    Stock mounts
    Bimmerworld Race Shifter
    Brakes PFC Rotors
    PFC 08 Pads
    Hard Motorsports Brake ducts
    Brembo GT BBK
    Click image for larger version  Name:	 Views:	0 Size:	233.1 KB ID:	29311
    Click image for larger version  Name:	 Views:	0 Size:	75.7 KB ID:	29371
    2003 Alpine White M3
    MCS 2-ways, 750 & 850lb, ML10RT 18x10.5 w/ 285 RE71RS, Hotchkis front & no rear, monoballs | Turner CSL, MAP conversion, Schrick 288/280, SS headers, BW sec2&3 | ATS 1.5way carbon hybrid, 4.10 FD | Brembo GT BBK, Cobalt XR1/3 | no aero
    IG: https://www.instagram.com/trlracing
    YT: https://youtube.com/@rlig
    That is one sweet stable you have there! I'm in Toronto and I'd count myself lucky to have even a 2 car garage.
      Thank you! Downside is I have to deal with a mile of dirt road to get home
      Love Toronto, looking forward to visiting again once the borders open.
        Based on your sig... I'm going to need to request pics of that new Raptor. Do you tow the M3 to the track with it?
          I do! The truck is heavy enough and easily has enough power, but the springs and dampers are soft so the rear squats pretty significantly. Looking into new leaf springs and bump stops so i can use an enclosed trailer.
            that a nice trailer! where did you purchase it? I am in the market for one as well. I am getting tired of driving the car after a hot track day with those track tires.
            2005 IR M3 Slick Top 6speed. Mods - too much to list!
            18 R8 RWS.
            19 Vantage
            15 YMB F80 M3 DCT - gone
            Other cars too boring to list.
              That's actually a rented U-Haul trailer, which i wouldn't suggest if your car is lowered - the "trays" for the tires have a lip that is high enough to interfere with parts underneath and rip bumpers off...
              Facebook marketplace and RacingJunk.com are good sources for trailer sales
                Nice build Ross! I too have a Magnetic Gen 2 Raptor towing an Alpine White M3 haha. Would you happen to have a pic of where/how you mount your AIM SOLO 2 DL? Mine is on the way and I want a good idea of where to mount it.
                Current: 2003.5 E46 ///M3 6MT - 2019 Ford Raptor 802A
                Past: 2015 F80 ///M3 6MT - 2006 E46 ///M3 6MT - 1999 E36 ///M3 5MT - 1991 E30 ///M3 5MT
                  Woo - sorry for the super long delay - I use a suction cup mount and place it just to the left of the gauge cluster. My steering wheel is smaller than stock so visibility is a bit better. It's a great spot to keep your eyes up, but still see splits and predicted times
                    Been a long time, lots of updates in the last few years. First, I finally landed on a clear direction for the car, time attack. It scratches my itch for a challenge, with competition and continuous improvement. Gridlife Street class rules seemed to fit my build specs better than either SCCA or NASA, so I focused on that. Unfortunately, the car is horribly outgunned in the class as it is now, with the front runners being 4 cylinder turbo cars that can easily hit 400+whp with a flat torque curve. Evos, STIs, CTRs, 718s etc.
                    Still, I enjoy the challenge of trying to improve my own times each year and am typically the fastest NA car in the class.
                    Car has changed in a few critical ways. Now around 340whp, depending on the day & dyno
                    Power:
                    • Installed Turner CSL intake & went full MAP conversion from kassel
                    • Added Supersprint headers and section 1
                    • Recently installed Schrick 288/280 mild lift cams
                    • Rebuilt vanos
                    Handling:
                    • Rebuilt dampers
                    • Nearly all bushings and joints are now delrin or spherical
                    • ATS 1.5 way carbon hybrid differential
                    • BMW 4.10 final drive gearset
                    • Took out a few more non-essential parts, ~3350lb with driver
                    I'm relatively happy with the balance of the car right now, other than always wanting for more power and torque. I've had two events on the ATS diff and 4.10, including Road America, and it did not hinder my top speed as much as I expected. In fact, gained some mph, likely from being able carry a few more through the corners. The diff is a huge improvement over stock. Lock up is extremely progressive and you can feel it really fighting for traction and distributing torque to the outside wheel. Needs a few more events to fully break in, I think, but so far so good. More to come this year
