Obioban's 2005 IR/IR Coupe
  • blazenXLT
    The brembos fit under the specific 17 I run (not most 17s), as do the 996 calipers I’m now running. I have 17x9.5 et35s ordered that I’m REALLY hoping fit over the 996 brakes... I really dislike the et25 setup for track use.
    I don’t really have any great garage ideas, beyond having it finally be large enough to not be annoyed. Open to suggestions!
    Interesting - I run 17x9.5 et35 all the time and have been thinking of a BBK upgrade soon, but I hate to buy something and have to just hope that it fits. I thought PFC made a BBK for fitting in a 17 but bimmerworld shows it as not available. Haven't done any more research though...
    On the garage I'd only offer the standard advice - you can't have too much space, power or light. On light I did ok in our build, but I do wish I'd added more outlets. I did run 220v to two places, so that should cover me for any future lifts, compressors, or EVs. And like I mentioned before, the space where I'd put a lift is 8 inches of 4000 psi reinforced concrete. I'll have to post up some pics in my journal thread.
  • Obioban
    Originally posted by blazenXLT View Post
    Your Brembos fit under a 17 inch wheel right? I think I remember you running 17s on the track.
    I'd also be interested in details on the new garage. We just moved into our new build in November. We expanded the garage in depth and width, put an extra high ceiling in the 3rd bay plus extra concrete. 99% sure a 4 post will go in late this year.
  • blazenXLT
  • Obioban
    Originally posted by Exclusivs View Post
    Solid feedback thanks. Any seat time on them yet? Thats where I'm anxious to know how they are
    The brakes? Yes, I drove them all last year, street and track. That was the basis of the feedback above...
  • Exclusivs
    I was driving on them last year. They're... 90% as good as the Brembo GT kit was. Better than stoptech or stock, and actually easier pad swaps than the brembos, but the pedal feedback isn't quite as good.
    Also, they're a not insignificantly heavier setup.
    But, FCP sells the wear items, sooo....
  • Obioban
    Slon wall didn't arrive in time for track season? Bummer, was looking forward to hearing your thoughts on it.
    Nope... been stuck in customs for a while. Not Slonik’s fault, but still sad.
  • heinzboehmer
    At this point I just need to finish a wiring harness I'm setting up, set the end links on the sways, and she's ready for the year
  • Obioban
    Nice updates Ian!
    Looking forward to hearing your take on the retro-fit, VS real GT kit
  • Exclusivs
    Nice updates Ian!
  • Obioban
    Originally posted by S14 View Post
    Looking good, I like your brake caliper stickers!
    Can you explain a bit more how you leveled your scales? Mainly, how did you shim to adjust the height and how did you set up the graduated cylinders?
    Ha. The stickers have double purpose-- hide the Porsche logo and tell me the caliper temperatures :P
    I have two graduated cylinders, connected by a tube at the bottom with 1/2" rubber fish tank line. I put water with food coloring (to make it easier to see) in there, and fill them both ~3/4 full. I shim under till both cylinders read the same, at which point I know they're level. I try to figure out which scale is the highest, and then use all the others to compare to that (shimming the others up). Once everything is shimmed up, I zero the scales so they don't contribute to corner weights.
    As shims, I use whatever the cheapest vinyl floor tiles I could find at Home Depot were (IIRC it was like $30 for 100 of them). They're ~1mm thick, so I can get reasonable leveling, and they're slippery-- so when I raise/lower the car, it doesn't get stuck high with the camber curve, and if I, say, adjust camber, I'm not fighting the friction of the tire on the scale-- the floor tiles just slide against each other.
  • S14
  • Obioban
    Good progress recently (later than I hoped, but... big undertakings this winter)...
    Leveled the scales:
    Installed the Fat Cats suspension, much primary colors:
    Installed the final tube of the brake ducting, and confirm it fits without issue in all positions:
    Confirmed I can fit a 275 Hoosier slick up front without rubbing on an et35 wheel (as that's about worst case):
    Aligned and corner balanced the car:
  • Obioban
    Bruh, pick up a new main board for like $15 bucks on amazon.
    They’re in the trash and not coming out. It was time to move on to not junk.
  • Obioban
    How do you like this? Is it a significant upgrade to the 3 and did you get the DSP option? I have the 3 now but BT and sound quality are not where I want them to be but I really like the OEM look.
    I’m not the person to ask about sound quality. My speakers are connected directly to the amp inside the Avin, and all the factory wiring harness/modules/mounting brackets have been weight saved. The remaining speakers in my car were chosen by weight, not sound quality.
  • Icecream
    Sadly at this point all 3 of my dremels had let out the magic smoke, so I'm on hold till a new rotary tool arrives. This time a made in Germany Proxxon tool. Can't last a shorter life than the dremel brand dremels...
