So you’ve done your rod bearings, the vanos lockdown, you set your own alignment, Subframe repaired, yada yada…..youre invincible right? You can do anything with this car right? You have amassed all the extra special tools, you have the torque spec thread memorized. Rebuilding the S54 may be your next project!!!
I wanted to add this to the forum, since currently it is lacking(it may be all that’s left lacking). Several members ive read in the past few months have been doing this and all have promised a post about it but ive not seen it yet. So maybe ill be the first!!! The reason no one has posted a diary or journal is that there is so much to describe, so much information and so many steps. Im sure to leave out quite a bit. I could write a 50 page book on this if not 100. So with this I hope some folks find it useful if they want to embark on this MAJOR project.
Now before I get going, I don’t recommend doing this!!!! I don’t recommend doing it how I did it or even suggest ive done anything that follows here correctly or the best possible way!!! This is only what I did and how I did it. There is quite possibly some steps I didn’t do that should have, very certainly somethings I wish id done differently or better, so this is not perfect. The hope is that ive learned a lot and my end result is a well running, reliable rebuilt S54. Ill take whatever power it gives, even if its less than stock lol. Feel free to add feedback, ive enjoyed learning about this process but always appreciate the knowledge here on the forum.
At this point ill list some parts and tools which you may not need all of this or you might choose to replace more items....this is just what i did, not taking the time to list part numbers, i detail how i found it all ahead.:
Special Tools Needed:
Cam Alignment Bridge
Rear Main Seal Tool(handle not needed)(saves $40 on the RMS Kit)
Ring File(borrowed)
Hoist(borrowed)
Crankshaft axial play dial(borrowed)--see TIS Crankshaft R/R
Stand, bolts for stand M12
11mm, 12mm, 1/2 in 12 point socket, for arp main and head fasteners and rod bolts.
Evaporust - Really good stuff!!!
Oil Squirter can
Brake cleaner(lots)
Wypall towels
Mineral Spirits or laquer thinner
Assembly Lube I used CLevite.
Break In Oil(Driven 15w50) It took 9L!
Gasket maker
Red and blue Loctite.
Micrometers(several for piston/crank journal sizes)
Bore gauge
Stretch gauge
Piston Ring Compressor
Ring spreader
Parts:
Pistons, Pins, Rods, Rings, Clips, CP/Carillo
Rod Bearings Clevite
Main Bearings King
ARP Head Studs
ARP Main Studs
Numerous Crush washers/orings: Oil filter housing, power steering, Vanos oil line, Cam Thrust bearing green o-ring, coolant pipe orings 3, cam pos sensor oring(2) Crank pos Sensor oring Fuel Line oring, Fuel injector rail orings 12, new cpv viton, lifetime water system oring upgrades(Wolfn8r). Dipstick o ring oil pan return crush. Intake manifold gaskets.
Gaskets: Head, oil pan(3), timing cover(2), vanos, water pump. Reused Valve cover gaskets and grommets etc..
Front main Seal(suggest purchasing at least 2), Rear main seal.
Flywheel bolts(8)
guibo(bolts if you must) it was time for mine, probably time for CSB too....
Belhousing metal gasket, probably not necessary, mine got mangled disassembling
Vibration damper bolts(4)
Plugs and Coils(only if its time)
Chain Tensioners(4) Timing chain top guide behind vanos
Fuel Injectors or service(optional)
Head Service(Lang stage 3) planed .003, new valve guides, seals, valves, springs
Crankshaft rod bearing journal widening, 3 bolts for sensor wheel, dowel for flywheel, pilot bearing.
Accusump/Accumulator for engine preoiling, and associated plumbing
O2 sensor(stuck in header)
Timing chain
Oil Chain
Oil Filters x 3
Lots of oil for oil changes during break in
PS Fluid
Coolant
Trans: Solid Pivot Pin, Spring, Throwout Bearing.
Block work:
Torqueplate bore/hone and plateau hone to 87.25mm
Deck surface block .005(not sure this much was necessary but its what he did and I cant put it back)
Clean and paint block
Hot tank: Oil Pan, Valve Cover, Timing Cover, oil filter housing--clean but looked like crap after so....
Painting w/ Engine Paint: valve cover, Oil filter housing/cap, Timing cover, Water pipe, Oil Pan, Tstat Housing.
Ring File(borrowed)
Hoist(borrowed)
Oil Squirter can
Brake cleaner(lots)
Wypall towels
Gasket maker
Bore gauge
Stretch gauge
Ring spreader
Parts:
Main Bearings King
ARP Head Studs
ARP Main Studs
Flywheel bolts(8)
Timing chain
Oil Chain
Oil Filters x 3
PS Fluid
Coolant
Block work:
