The Red Drift ///Machine - 2026 NASA TT4 adventures
    Remind me which Bilsteins are the starting point for these? Real nice that it’s a weight reduction.
    edit: TCK shaft could be bent too. It’s pretty thin.
    I'll check that, wasn't obvious.
    Any non-adjustable monotube. I chose the non-M PSS which were $150 less than the M3 PSS. I think a B6 or B8 works.
      Re: camber, We talked about this in your other suspension thread and I forgot to ask... has the strut tower moved? is the sheetmetal between the tower and apron torn?
      Email to [email protected]
        No evidence of blown spot welds, creases or movement. The strut bar still lines up without issue. Bry5on's reinforcement plate lined up perfectly. Nothing has led me to believe something shifted until this camber issue.
        To me, the knuckle being bent makes sense. I replaced the wheel bearings Oct 2022, off was Jan 2025, right bearing goes bad Mar 2026.
