Hi all - Been meaning to resurrect my M3Forum thread for a while now. It'll take some time since I lost the old material, but I figured some media and a parts list would be a good start. I'll write more about this 3 year build, my introduction to track days, and other E46 adventures in future posts. Thanks for reading!
Body and Paint:
- 2002 E46 M3 TiAg chassis with 160k miles
- Lang Racing CSL-style Carbon Fiber Roof with OE CSL rails
- Status Gruppe SCZA CSL-style Trunk Lid, Fiberglass
- Status Gruppe Prepreg Carbon Diffuser
- Status Gruppe CSL front bumper cover modified to accept OE kevlar front bumper
- Hard Motorsports retractable tow hooks front and rear
- Southern Polyurethanes, Inc. Epoxy Primer
- Motobase LV, Sapphire Blue Metallic (M5J)
- Southern Polyurethanes, Inc. Universal Clearcoat
- Porsche 996 calipers powdercoated Brembo yellow and rebuilt with Stoptech seals
- RallyRoad conversion brackets
- CSL/ZCP rotors
- PFC08 track pads, Hawk Ceramic street pads
- RBF600 brake fluid
- Custom 3" brake ducting from CSL bumper center intake through OE skidpan
- MK20 -> MK60 conversion with custom copper-nickel lines
- Updated cluster with M-track mode
- Recaro Pole Position seats with sliders
- Macht Schnell floor adapters
- Schroth 6-point harnesses with trans-tunnel-mounted inner lap belt
- Helmet and HANS
- Custom weld-in half cage in 4130 from Wick's Aircraft Supply
- Harry's GPS Laptimer with Bluetooth OBD2 integration
- SkyPro XGPS 160 on rear deck
- Cage-mounted GoPro HERO4
- Retained and rebuilt A/C and heater
- Hard Motorsports plastic door panels and pull straps
- Karbonius CSL airbox and carbon flap-delete snorkel
- 288/280 CatCams
- Mahle Powerpak 11.5:1 87.5mm pistons
- Supertech valve springs with stock retainers
- Beisan VANOS disc, seals, and solenoid coilpack
- OE ECU converted to CSL running nearly-stock CSL tune
- GM MAP sensor teed off FPR line mounted next to MK60 module
- ATI Harmonic Damper
- Turner underdrive pulleys
- Walbro GSS342 255lph fuel pump installed with Radium kit and new PTFE line
- Fuel starvation prevention using E36 fuel pump in driver's level sender location
- OE motor mounts, Rogue Transmission mounts
- OE radiator
- SPAL puller on Massivebrakes brackets. Engine fan deleted
- CPI single-step headers ceramic-coated by Swaintech
- CPI catted/resonated section 1
- OE section 2 and muffler
- Mishimoto oil cooler kit
- Radium catch can in SAP location
- Updated oil return line with AN fitting in early oil pan
- Rogue VANOS oil line
- Retrofitted Lightwerkz FXR 3.0 projectors
- Osram Xenarc 66420 CBI HID bulbs
- 03.5 LCM/LSZ flashed with newest software
- OE LED tail lights with factory wiring from '05 harness
- Steering wheel wrapped in perforated leather from eBay user tainik
- ZHP rack from RackDoctor
- OE high pressure line
- Custom front-mounted cooler with AN hardware
- Apex ARC8 18x9.5 ET35
- 265/35ZR-18 Hankook Ventus R-S4
- 5mm front and 12mm rear wheel spacers
- Rogue studs and nuts
- MCS 1WNR with coilover rears and Hyperco helper springs
- Hyperco 350# fronts, 325# left rear, 300# right rear
- Hotchkis front sway bar. No rear bar
- Ground Control race camber plates at minimum -3.2* camber
- ECS adjustable rear lower control arms
- Bimmerworld RTABs provided balljoints joints replaced with Lemforder units
- Turner delrin monoball FCABs
- Rebuilt, second-hand Diffsonline 3-clutch BMW LSD
- 3.91 BMW Motorsport R&P
- OE diff bushings
- Turner solid aluminum rear subframe bushings
- VinceSE2 extended rear diff bolts
- Custom Vince-style topside RACP reinforcement front and rear
- Redish RACP underside reinforcement plates
- Rogue performance clutch kit with steel single-mass flywheel
- Autosolutions 30% SSK
- Bimmerworld Jaffster tall delrin shift knob
- Rogue stainless clutch line
- 6MT conversion. Bellhousing converted by Lang Racing
- Dinan strut tower brace
- Hardwired visor-mount Valentine One with JBV1 via Bluetooth
- Voltphreaks VPR-P6 mounted in passenger's engine bay bin
. That green paint job is sweet nice choice
