2002 Steel Grey 6spd coupe Daily/Restoration project
    Awesome! Congrats on joining the steel grey crew! It looks amazing in the bright California sunshine. Can't wait to see how this build progresses. Love to see e46's end up with someone who is going to take great care of them.
      I love this colour! So OG. Congratulations. This will be a fun Project.
        Been following your progress on Insta and amazing work on restoring it so far. Looking forward to more updates.
          Thanks Ejaz! It's so easy to post progress on Insta stories, but here, I have to remember to post more.
            Fixed the broken trunk handle
            Click image for larger version  Name:	trunkhandle8.JPG Views:	0 Size:	85.9 KB ID:	108964
            Then I uninstalled this mess of a sound system:
            Click image for larger version  Name:	SG0223214.JPG Views:	0 Size:	166.0 KB ID:	108966
            Click image for larger version  Name:	SG0223217.JPG Views:	0 Size:	183.6 KB ID:	108967
            I'll clean up the harness later with amp install. Look at this ground they did lol:
            Click image for larger version  Name:	SG0223216.JPG Views:	0 Size:	136.3 KB ID:	108965
            Found a nice looking oem battery under the sub tho
            Click image for larger version  Name:	20210603_222905.jpg Views:	0 Size:	185.9 KB ID:	108973
            Oh there's the bracket and more debris
            Click image for larger version  Name:	20210603_222931.jpg Views:	0 Size:	223.7 KB ID:	108974
            Cleaned the hardboard
            Click image for larger version  Name:	20210603_223624.jpg Views:	0 Size:	232.8 KB ID:	108977
            With new hardware, got the battery secured
            Click image for larger version  Name:	20210603_223703.jpg Views:	0 Size:	185.7 KB ID:	108979
            Pulled passenger door to fix window, they put in some shitty 5.25" coaxials lol
            Click image for larger version  Name:	20210603_223913.jpg Views:	0 Size:	129.0 KB ID:	108976
            The window wouldn't move, no wonder:
            Click image for larger version  Name:	20210603_223825.jpg Views:	0 Size:	105.2 KB ID:	108975
            And the gear wore itself out so I need a motor too
            Click image for larger version  Name:	20210603_223845.jpg Views:	0 Size:	194.5 KB ID:	108978
              Got the glass out and put it in the sun so tint just peeled right off
              Click image for larger version  Name:	regulator22.JPG Views:	0 Size:	278.4 KB ID:	108983
              Replacement regulator with motor. You might notice the vapor barrier missing.
              Click image for larger version  Name:	regulator23.JPG Views:	0 Size:	173.1 KB ID:	108982
              So I sealed it up cheaply. Those thick, reusable plastic shopping bags are useful!
              Click image for larger version  Name:	vaporbarrier02.JPG Views:	0 Size:	154.4 KB ID:	108981
              Installed a new outer door trim to finish. All of the trims need replacement
              Click image for larger version  Name:	20210603_233413.jpg Views:	0 Size:	71.5 KB ID:	108985
              Checked the areas you might see cracks/separation, in the trunk, and find zero evidence. The same for what's visible underneath. I'm not in a hurry to address the racp (other than add rear strut brace for more rigidity) esp not really driving much anymore with WFH
              Click image for larger version  Name:	20210603_223946.jpg Views:	0 Size:	128.5 KB ID:	108984
              Went to install stereo power wire, and noticed debris down in battery tray so ended up pulling battery out. Seems like water's getting behind taillight.
              Click image for larger version  Name:	20210603_233750.jpg Views:	0 Size:	143.0 KB ID:	108986
              Cleaned
              Click image for larger version  Name:	regulator24.JPG Views:	0 Size:	181.6 KB ID:	108987
              Power wire/fuse holder installed, and battery back in
              Click image for larger version  Name:	20210603_233940.jpg Views:	0 Size:	159.8 KB ID:	108988
                nice work so far. I have an extra set of brand new trim for the rear 1/4 windows. I'll give them to you
                2007 Imola Red Z4M Coupe
                  Very nice
                    subbed
                    damn lot of work my head hurts just reading this shit man fuck that water
                      Thanks guys!
                      Lots to post, still have silvergrey content too, but trying to catch up here
                      Rear view mirror was leaking, so put in an e34/36/38 era one that I have in silvergrey too from my old 325i. Simple, light, wide.
                      Click image for larger version  Name:	thursday6.JPG Views:	0 Size:	186.3 KB ID:	109410
                      Took the front bumper/cover off to fix it, using a new pass lower liner and guides, but also remove washer tank/pump
                      Click image for larger version  Name:	20210603_235309.jpg Views:	0 Size:	141.0 KB ID:	109409
                      Put it in front of Silvergrey and you really see how light silvergrey is. I focus on steel for a while and then see silverg & it looks like tiag to me lol. Imo, steelgrey is too dark, and it just feels very prefacelift I know how that sounds, but I can't shake it. Maybe it's condition makes it seem older too.
                      I have to say, honestly, I have an even deeper love of silvergrey after owning steelgrey now for a bit. Steel is too dark except in sunshine, but not dark enough to give the reflections of schwarz. It's a bit lost, a bit muddy. Too much color as well, looks purple brown a lot. In sun, it's absolutely brilliant. Silvergrey in sun is too bright! It's beautiful, but hard to look at without straining sometimes (my eyes are sensitive tho). In all other lights, silvergrey is sublime. It also contrasts better with the non painted surfaces than steel does. Silvergrey is also the (main) csl color ofc, so ya.
                      Then there are moments, in the right light where steelgrey looks it's lightest, at first glance, I mistake it for how dark I know silvergrey to get in the right light. It's a trip.
                      _
                      Sold the 128i to pay for e46. Twas a decent car but nahhhh too goofy, too short of a wheel base. Too cheap inside, too new for me. New owner appreciated the slicktop 6spd which I'm glad about. Adios.
                      Click image for larger version  Name:	128sold01.JPG Views:	0 Size:	88.3 KB ID:	109411
                      Click image for larger version  Name:	bumper08.JPG Views:	0 Size:	200.2 KB ID:	109412
                      Everything was really dirty, but dry, and lots of debris, ofc
                      Click image for larger version  Name:	20210603_235647.jpg Views:	0 Size:	180.1 KB ID:	109414
                      Hosed it all down, scrubbed it
                      Click image for larger version  Name:	image_24598.jpg Views:	11 Size:	213.7 KB ID:	109415
                      I then spray anything black (plastic, vinyl, rubber) with this meguiar's product. Same as the professional auto stuff, but half the price. It does a great job at cleaning and renewing. I still like 303 for the interior, but this stuff is just as good, if not better for exterior. Makes the perfect tire tressing imo. You can dilute too.
                      Click image for larger version  Name:	20210603_235627.jpg Views:	0 Size:	173.7 KB ID:	109416
                      Click image for larger version  Name:	20210603_235727.jpg Views:	0 Size:	160.5 KB ID:	109423
                      Ducting after wash/condition/dry:
                      Click image for larger version  Name:	thursday14.JPG Views:	0 Size:	82.3 KB ID:	109418
                      Tank down and out/disconnected in 3 spots iirc since this car has headlight sprayers.
                      Click image for larger version  Name:	washer07.JPG Views:	0 Size:	109.3 KB ID:	109421
                      Click image for larger version  Name:	washer12.JPG Views:	0 Size:	78.6 KB ID:	109420
                      New lower liner vs old torn up one
                      Click image for larger version  Name:	washer04.JPG Views:	0 Size:	194.5 KB ID:	109422
                        New bumper guides, liners ready
                        Click image for larger version  Name:	fcp12.JPG Views:	0 Size:	75.6 KB ID:	109432 Click image for larger version  Name:	fcp14.JPG Views:	0 Size:	87.0 KB ID:	109434
                        Forum member Bassel wanted me to have new oe grills thank you!
                        Click image for larger version  Name:	thursday5.JPG Views:	0 Size:	159.2 KB ID:	109435
                        Luckily found a set of bimmian painted reflectors in steelgrey for $40! Inventory is low (no longer being made?), some colors are out of luck. Ind has them for $110 iirc.
                        Click image for larger version  Name:	20210603_235426.jpg Views:	0 Size:	83.9 KB ID:	109433
                        Removed the lower headlights trims and sprayers
                        Click image for larger version  Name:	thursday12.JPG Views:	0 Size:	81.1 KB ID:	109436
                        Cleaned and conditioned them
                        Click image for larger version  Name:	thursday15.JPG Views:	0 Size:	232.1 KB ID:	109438 Click image for larger version  Name:	thursday18.JPG Views:	0 Size:	233.5 KB ID:	109437
                        Glued the rubber edge gasket back on at the ends (common issue)
                        Click image for larger version  Name:	thursday21.JPG Views:	0 Size:	97.0 KB ID:	109440
                        Found like new headlight lenses (AL) on ebay for cheap, score!
                        Click image for larger version  Name:	128sold23.JPG Views:	0 Size:	78.3 KB ID:	109443
                        Sliding the bumper back on
                        Click image for larger version  Name:	128sold12.JPG Views:	0 Size:	199.0 KB ID:	109442
                        Click image for larger version  Name:	128sold14.JPG Views:	0 Size:	70.2 KB ID:	109439
                        I can tell the bumper's been resprayed. Looks like the rear is too as well as the pass door/qp. I was hoping it was more original, but it's understandable for this 19 y/o car owned by a regular person. PO vaguely remembers, but not why the door and qp. Perhaps keying.
                          Love watching the work on this brother!
                            Dogg get new door insulation, that shit would drive me nuts it's only 40 bux 51488204283.
                            Love me some fresh plastics.
                              84 would be passenger side btw
                                Motivating me to get back in the garage, great progress!
